-   -   *****help with my s14!!!****** (#/f/showthread.php?t=277406)
rob22 09-08-2009 03:33 PM
i have a 98 s14
i have a nissan manufacturer specific code
turns out its P1605 A/T Diagnostic Communication Line
how would i go about fixing this?
n e help would be appreciated thanks!
FaLKoN240 09-08-2009 05:21 PM
Sounds like you need an OBDII tranny.
rob22 09-09-2009 02:59 AM
why would i need an obdII tranny?
devnull 09-09-2009 03:14 AM
The FSM says that P1605 could be the result of a wiring problem between the A/T control unit and the ECU. There's a red wire with a black stripe is the comm wire between the A/T control unit and the ECU. You should check that wire for continuity.
rob22 09-09-2009 01:13 PM
alrite thanx 4 the help!
