-   -   need help with brakes (#/f/showthread.php?t=186996)
joshy240sxxx 04-12-2008 05:52 PM
hey guys have a newbish question how do i get the front caliper piston to go back so i can get the pads to fit. thank you.
ps. sorry if its been covered i searched but didnt get a answer.
Signum Temporis 04-12-2008 06:01 PM
put the boot in the cylinder but not all the way in, just so that the little notches line up, put the piston into the boot, then push the piston in so that the notches line up on the piston and cylinder. heres a picture from the FSM :bigok:... http://img01.picoodle.com/img/img01/...nm_2c621ea.jpg
joshy240sxxx 04-12-2008 06:09 PM
thanks alot man
Signum Temporis 04-12-2008 07:00 PM
did it work out?
shade 04-12-2008 11:14 PM
I used to just hammer the piston back in when I have the bleeder valve open or the brake line off when I had stock brakes. I can't do that anymore since I upgraded to Z brakes.
Signum Temporis 04-12-2008 11:17 PM
please, for ur own sake if anyone decides to "hammer" the piston back in, use a rubber mallet.
