| OneSicSilvia |
12-23-2011 02:25 PM |
No marker lights S14
I poked around to see if I could find an answer buy pretty much everything I've tried has been a no go. As the title says. When I turn the marker lights on, nothing happens, no lights at all. My headlights work though, high and low beams. all 4 of my blinker lights work, Brake lights work, and reverse lights work. I just replaced the Blinker switch on the column in hopes that would fix it, as it was the issue on my old S13. I've replaced the bulbs and fuses. Is there a main relay or something?. Its certainly a aggravating little bugger, what ever the issue is. Any input on this as to soemthing I may have missed would be awesome. Thanks.
