-   Nissan News (#/f/forumdisplay.php?f=85)
-   -   Video: 2011 Nissan Juke to get 1.6L gas-turbo-direct-injected I4 (#/f/showthread.php?t=305576)
ZilviaBot 02-13-2010 03:00 PM
02-12-2010 05:29 PM
Filed under: Technology, Crossover, Nissan
http://www.blogcdn.com/green.autoblo...uke-engine.png
When Nissan's new Juke compact crossover hits the streets later this year, it will be powered by the automaker's first gasoline-turbocharged-direct-injected (GTDI) engine. Following in the same technical path blazed by the Volkswagen Group, General Motors, Ford and others, the new engine uses the high-pressure injection system to execute multiple injection pulses for cleaner and more complete combustion. The variable cam phasing system operates independently on both the intake and exhaust camshafts, but the bottom line is this: An impressive 188 horsepower and 177 pound-feet of torque from a small displacement engine.
We don't know for sure if this new mill will come to the U.S.-market Juke, but we assume it will, likely paired with either a six-speed automatic transmission or one of Nissan's continuously variable transmissions. We also have no idea what kind of mileage the GTDI Juke will get, but it should be quite competitive. Check out the video after the jump to see it in action. A tip of the hat to Braun!
Gallery: Nissan Juke
http://www.blogcdn.com/www.autoblog...._thumbnail.jpghttp://www.blogcdn.com/www.autoblog...._thumbnail.jpghttp://www.blogcdn.com/www.autoblog...._thumbnail.jpghttp://www.blogcdn.com/www.autoblog...._thumbnail.jpghttp://www.blogcdn.com/www.autoblog...._thumbnail.jpg
[Source: Nissan via YouTube]Continue reading Video: 2011 Nissan Juke to get 1.6L gas-turbo-direct-injected I4
Video: 2011 Nissan Juke to get 1.6L gas-turbo-direct-injected I4 originally appeared on Autoblog on Fri, 12 Feb 2010 18:29:00 EST. Please see our terms for use of feeds.
PermalinkÂ*|Â*Email thisÂ*|Â*Comments
http://feeds.feedburner.com/~ff/webl...GU:wF9xT3WuBAs http://feeds.feedburner.com/~ff/webl...GU:V_sGLiPBpWU
http://feeds.feedburner.com/~r/weblo...~4/2MkFgT-88xc
More...
upsdude 02-13-2010 03:12 PM
wow that's an ugly front end...looks like the pontiac aztec
Bushido 02-13-2010 07:56 PM
pontiac aztec? you must be blind.
