Enjuku Racing - ISR Performance S13 Powersteering Kit
ISR Performance Power Steering Kit - Nissan S13 240sx http://cdn2.bigcommerce.com/server24...00.659.jpg?c=2 ISR Power Steering Kit - Nissan S13 240sx w/ KA24DE, SR20DET ISR Performance Black Aluminum Baffled Reservoir with -8AN and -10AN Outlets -8AN Black Nylon Hose to the Rack -10AN Black Nylon Hose to the PS pump -6AN High Pressure Power Steering Line The ISR Power steering Reservoir Kit eliminates the oem reservoir but mounts in the oem location using the bracket provided, The high quality nylon braided hose with AN fittings do away with the oem rubber and hard lines to get rid of the common leaks in S-chassis. This Reservoir Kit was designed for those who want replace all the factory lines of the power steering including upgrading the oem high pressure line with the ISR -6AN braided high pressure line. If you already have an upgraded high pressure power steering line or want to reuse your oem and just want to upgrade you reservoir and low pressure lines you can purchase the reservoir kit here: http://www.enjukuracing.com/products...s13-240sx.html **THIS KIT DOES NOT WORK WITH HICAS PUMPS.** In Stock and Ready to Ship! $269.99 https://cdn2.bigcommerce.com/server2...g?t=1468417993 |
Should work with a hicas pump if someone is using one with a non-hicas chassis and already gutted the hicas rack pump internals.
I used the ISIS high pressure line with a hicas pump on my non-hicas s13. |
Question.
What makes this kit different compared to the Chase bays kit? |
There isn't any difference in functionality, but the brackets are definitely different. The ISR Performance Bracket retains the factory location for the reservoir.
This is great! Will definitely have to pick up for my next application.
Random but related, is there any way I could get the fitting that comes with the high pressure line that goes between the pump and the line? I lost mine :'(
savage lol |
Why would I get this if I have a functioning power steering system already? Relocating power steering reservoir
Hello Jumboflan,
You could relocate it, but this kit is designed to put it right back in it's factory location with new lines and reservoir. If you wanted to "dress" your engine bay this will help it look cleaner. It's all matter of opinion, but if what you have works why replace it? Thank you! Ramon |
Hey TheRealSy90,
We have them available for sale individually: http://www.enjukuracing.com/products...ing-240sx.html Thank you! Ramon |
That's the fitting that gets threaded into the pump itself? Looks like the rack side fitting. If so thanks. |
Hello TheRealSy90,
Yeah that's the rack side, sorry. I do have the Pump Side Fitting but we don't have it listed on the website. Price is: $9.99 + Shipping (Flat Rate USPS Box $8) You'd have to call and ask for me I have it in my hand. Thank you! Ramon |
| All times are GMT -6. The time now is 11:56 PM. |
