-   -   s14 Electron Batt Fuse in, starter won't turn over. Fuse out, starts right up. Help? (#/f/showthread.php?t=605919)
gregsqueeb 06-18-2015 10:47 AM
Hello Everyone!
I recently replaced my headunit with a newer one on my '95 s14. When I went to put everything back together the radio would not turn on. I checked some of my fuses and the Electron Batt fuse was blown. I replaced that fuse and the radio turned right on. Yay! But now the starter does not turn over.
When I take the fuse out the car starts right up, but the radio doesn't work.
Any ideas?
badP4nda 06-30-2015 12:08 PM
Bump, i think i have the same issue and would like to know what to do haha!
gregsqueeb 06-30-2015 12:16 PM
This has not happened to me again. I checked my check engine light and it said that there were 2 starts where it did not sense the clutch pedal was pushed all the way down. Maybe that has something to do with it?
kruked 06-30-2015 03:48 PM
This paragraph makes no sense.
gregsqueeb 06-30-2015 04:14 PM
Lol, thanks.
When I checked the Check Engine Codes through the consult port I had 2 code 1003's (Park/Neutral Position Switch) which would cause the car to not turn over. I am thinking this might have been my issue when it would not start.
