BLG_S13.5 - Smarter Than Your Average Bear
It's been a while since i posted on here....
so why not a better time than to document my new toy/build/stupid idea etc etc any how here are some specs of the Body Bayside Blue with Azureus Blue Pearl and Black roof S15 Front End Conversion S13.5 30mm Wide body Conversion Front Guards S13 50mm Wide body Over Fenders Vertex Body Kit Vented S15 Hood Origin GT1 Side Mirrors Origin Smoked s13 Rear Lights Origin Carbon Fibre Rear Window Lip CA18DET Boot Lock Badge Flush Mount Bonnet Pins Walker Chassis Full Weld In Cams Approved Roll Cage Suspension HSD HR Coilovers GTR Rear Sway Bar with solid mounts HICAS Lock Bar GTR Rear Cradle Off-set Alloy Cradle Bushes Project D Adjustable Rear Camber Arms Project D Front Castor Arms Braking R32 GTST Front Calipers R32 GTST Rear Calipers DBA T3 Slotted Front Rotors Bendix Ultimate Brake Pads All Round Wheel's Riverside Stitch Mesh 17x10 Fronts Work CR Kai 18x10 http://i74.photobucket.com/albums/i2...78889337_n.jpg http://i74.photobucket.com/albums/i2...96797749_n.jpg http://i74.photobucket.com/albums/i2...74930434_n.jpg http://i74.photobucket.com/albums/i2...73149692_n.jpg One of the first things i did once i got the shell home was to paint the horrid camo on the lower section of the dash :doh: http://i74.photobucket.com/albums/i2..._01/1%2016.jpg Next up was to remove the driveline from my old silvia http://i74.photobucket.com/albums/i251/G15_01/1%203.jpg During the process i decided to strip everything off the motor and give it a clean up as my OCD decided to kick in mildly http://i74.photobucket.com/albums/i251/G15_01/1%207.jpg http://i74.photobucket.com/albums/i251/G15_01/1%204.jpg Next was to fit everything back to the motor http://i74.photobucket.com/albums/i2..._01/1%2010.jpg And give the engine bay a quick spray.. http://i74.photobucket.com/albums/i251/G15_01/1%209.jpg an den... http://i74.photobucket.com/albums/i2..._01/1%2017.jpg http://i74.photobucket.com/albums/i2..._01/1%2029.jpg previous to this my good mate and i decided the loom needed a freshen up so we took to stripping all the conduit off and cleaning everything and even modifying a few things here and there such as the Fuel Injector Loom http://i74.photobucket.com/albums/i251/G15_01/1%206.jpg http://i74.photobucket.com/albums/i2..._01/1%2026.jpg http://i74.photobucket.com/albums/i2..._01/1%2012.jpg Also wired up the battery cable to go into the cabin http://i74.photobucket.com/albums/i2..._01/1%2018.jpg http://i74.photobucket.com/albums/i251/G15_01/1%205.jpg http://i74.photobucket.com/albums/i2..._01/1%2028.jpg http://i74.photobucket.com/albums/i2..._01/1%2023.jpg http://i74.photobucket.com/albums/i2..._01/1%2024.jpg Taking on something like this became overwhelming but luckily the fridge is stocked with beer and the boys are always nearby to help out :humpleg: :humpleg: haha it was finally taking shape !!! http://i74.photobucket.com/albums/i2..._01/1%2013.jpg http://i74.photobucket.com/albums/i2..._01/1%2030.jpg http://i74.photobucket.com/albums/i2..._01/1%2014.jpg http://i74.photobucket.com/albums/i2..._01/1%2021.jpg http://i74.photobucket.com/albums/i2..._01/1%2022.jpg Right now that's as much that i can do on the car due to a back injury... but very soon she will be blazing tyres around Mallala !!!! |
| All times are GMT -6. The time now is 10:16 PM. |
