350z Rear Axle Problems, Someone Please Help!!!
hey guys so i got my rear axles replaced because they were on their way out, anyway..last week my axle shaft came out of the differential on the freeway and luckily i had an early morning shift so i was able to pull over on the freeway because my car wouldn't go into gear. So i had the axles replace and when we were changing the axles we noticed the shaft (picture below) was outside of the differential, i got a flashlight and looked inside and the c-lock (other picture below) was inside mounted in the differential and to my understanding it has to be on the axle shaft right? anyways we put it together like that and yesterday i drove it around the city with no problems, i was coming back home late at night and at a red light my car didn't move in gear i got out and checked under the car and the shaft came out once again. Why is this happening? all bolts are torqued down to spec, the only issue I'm confused about is why the c-lock is inside the differential mounted instead of the axle shaft, do i take it out of the differential and put a new one on the axle? Wekfest Long Beach is in 3 weeks and my car is finally done just this problem is whats slowing me down and I'm afraid i won't be able to show at wekfest luckily tuesday is my last day of school so i can just take my brothers car. someone PLEASE help I'm desperate for advice.
picture is not my differential its just for reference my car is an 04 6 speed with non lsd if it matters here is the axle shaft that keeps popping out, and its only this side that it keeps happening, when installed properly inside the differential how hard should it be to take it out in other words how snug should it fit inside there? http://i1177.photobucket.com/albums/...psbc401982.jpg and here is the c-lock i have http://www.courtesyparts.com/38225-c...8-p-15545.html |
No way should it just slide out...
Yeah that shouldn't be happening
( If I remember) There is a retainer or C lock inside the diff that prevents the Axelshaft from just coming out. Its been a really long time since I have opened up one of these pumpkins but this is definitely not normal.
| All times are GMT -6. The time now is 07:09 AM. |
