Enjuku Racing - ISR Performance 70mm Wheel Studs for Nissan 240sx
ISR Performance 70mm Long Wheel Stud for Nissan 240sx http://cdn2.bigcommerce.com/server24...00.659.jpg?c=2 ISR Performance 70mm Long Wheel Stud for the Nissan 240sx ISR Performance 70mm long wheel studs replaces the factory studs with longer studs that can be used with added wheel spacers and open ended lug nuts. Made for factory Nissan hub knurl Only. These 70mm long wheel studs are an improvements over the OEM wheel studs. Utilizing stronger heat treated materials and coating for extended strength and durability. Specs: 70mm long Easy Start Threads S14 Front Hubs - 14.25MM KNURL S13 Front/Rear Hubs and S14 Rear Hubs - 12.85MM KNURL M12 x 1.25mm Thread Pitch * Please choose the studs accordingly for your application. * Price is for one stud. Please order the number of studs you need accordingly. In Stock and Ready to Ship! $2.39 https://cdn2.bigcommerce.com/server2...g?t=1468417993 |
Can these be used on the ISR 5 lug hubs?
Bump, In Stock! Measure the Knurl Sizes to see if it matches your ISR Hub, but the current ISR Hubs are now consistent with the Nissan Wheel Stud Knurls. In past years they were hit or miss on knurl.
| All times are GMT -6. The time now is 01:06 AM. |
