-   -   Cadillac CTS-V brake upgrade (#/f/showthread.php?t=643457)
Blue55 03-15-2017 12:33 PM
I'm working on a 4 piston CTS-V brake upgrade on my S13. I'm swapping out the master cylinder for a Z32 one. Is there any way of getting the fitting out of the old master cylinder without destroying it? Seems like a ton of delicate work.
Here's an article on getting the old fitting out
http://importnut.net/the-definitive-...cylinder-swap/
FYI - I'm doing a video on the swap and I'll post it later when it's done.
rawgarage 03-15-2017 08:24 PM
Who cares about destroying your old s13 BMC
alwaysnboost 03-15-2017 08:28 PM
True ^^^^^^^^^^^
cespana 03-17-2017 02:35 PM
Do it...nobody is buying S13 oem master cylinder.
Blue55 03-17-2017 06:34 PM
It's not cost, it's just a pain in the butt is all!
Blue55 03-17-2017 06:36 PM
I just made a very detailed video of the install process:
http://www.youtube.com/watch?v=gH20d_pfz6s
ph1tnessjunk1e 04-08-2017 07:29 AM
I saw that video a few days ago and it's awesome :) What do you do for the rear brakes though?
Blue55 04-08-2017 01:09 PM
I'm going to do the z32 rear brakes but that's a whole separate project.
bjreynolds202 04-11-2017 05:22 PM
How is the braking with the cts v up front and stock rears? Saw the video a few days ago, nice to see you on here too!
Blue55 04-12-2017 07:49 PM
The car has been sitting on jackstands for too long since I've been traveling. I had a leaking hard line into the master cylinder so hopefully I've fixed that now.
My plan with any luck is to get to a track day this weekend and properly test it out. There will definitely be a video!
crzsteveo 04-12-2017 08:16 PM
Mine is 100% front brake bias with stock rears... which is great because my rears are almost seized (hypothetically) i would like to keep my stock rears, and some how hydraulic pressurized them so I can utilize my stock ebrake while doing a dual caliper bracket with wilwoods calipers to help bias with proportional valve....
Blue55 04-13-2017 02:15 PM
Originally Posted by crzsteveo (Post 6186644)
I would like to keep my stock rears, and some how hydraulic pressurized them so I can utilize my stock ebrake while doing a dual caliper bracket with wilwoods calipers to help bias with proportional valve....
I may add a proportioning valve after I test it at the track this weekend.
Here's the second part of the video
http://www.youtube.com/watch?v=eTiXeA2158Y
mad-ass 04-14-2017 02:32 AM
you installed left and right side backwords, unless you bought two left sides. other wise you wouldn't have had to swap the brake line/bleeders over.
good video though.
Blue55 04-20-2017 12:30 PM
good video though.
They were not installed backwards. The brake line is at the top of the caliper, not the side.
onehundredoctane 04-20-2017 12:41 PM
Aren't those calipers heavy?
Not sure why people are paying top dollar for those when Wilwood 4 piston calipers are lighter, and cheaper. . . ? Is unsprung weight still not a thing?
Agamemnon 04-20-2017 02:26 PM
He means that the bleeder screw faces upward and the cross over tube is on the bottom of the caliper. You either got 2 of the same side or installed them on the wrong side.
http://cadillacfaq.com/faq/answers/bpadchange/1.jpg
bjreynolds202 04-20-2017 06:06 PM
Do you have the weights or weight difference between a front wilwood setup vs stock front? Ive been looking but I can't find definitive weights for either the wilwoods or cts - v setup.
cts-v swap can be found for close to 800 dollars, willwood is a bit over 1k, that $200 would totally be worth it if they are significantly lighter than the cts-v's...
My guess is that the advantage in weight is wilwoods 2-piece rotor vs the cts-v rotors being monstrous.
onehundredoctane 05-04-2017 04:30 PM
The Wilwood Superlites I run are 4 pistons and weight less than 5lbs each. They're a good deal at less than $180 per caliper. I use a bracket that allows to run a 350z brake rotor, so it's a very simple upgrade. Very cost effective, and weights virtually nothing compared to the stock caliper. According to Google, the CTS-V caliper weights 8 lbs.
I upgraded to Wilwood years ago, can't remember exact cost, but it was less than $450 in all of it.
tb13 05-04-2017 04:37 PM
I'm also running a 4 piston Wilwood Superlite setup. I had thought about running a bastard CTS-V/350z setup, but the extra few bucks I spent was well worth it. Wilwoods are much lighter and have huge pads plus I got 2pc 13in rotors which are super light. My setup is from Arizona ZCar and was around $1k
http://i.imgur.com/LJ4JV7Rl.jpg
http://i.imgur.com/iKuoyJyl.jpg
onehundredoctane 05-04-2017 04:51 PM
Track Proven on Facebook has the adapter brackets to put the wilwood calipers on the S and Z chassis and are very affordable! Couple that with one piece 350Z rotors and it's super cheap.
tb13 05-04-2017 05:01 PM
Do you know if they offer any solutions for the rear? Really wanting to swap some 6pots up front and move my 4pots to the rear.
onehundredoctane 05-04-2017 06:44 PM
I've been trying to talk Andy, the owner, in to designing a rear set up based on the Z32 rear rotor. Nothing so far though :(
tb13 05-04-2017 06:45 PM
Might shoot him an email, show some more interest and see if he bites.
alwaysnboost 05-04-2017 06:52 PM
Love my wilwoods wouldn't trade them for anything
onehundredoctane 05-04-2017 07:31 PM
Last I checked, he just needed a rear 5 lug hub, as I already have a rear knuckle I could loan him for mock up. He no longer owns an S chassis and does all mock up on his work bench.
Blue55 05-07-2017 03:05 PM
=onehundredoctane]
I found a set of caliper for $250. Significantly cheaper than the $360 you spent.
Anyway, there are several good solutions. I'm glad Wilwood works well for you.
onehundredoctane 05-08-2017 09:06 AM
You paid $250 for used calipers?
crash n' burn 05-08-2017 12:16 PM
Didn't think Andy was still doing stuff for the S-chassis. I thought the F40 brackets were the last ones.
RalliartRsX 05-08-2017 12:30 PM
For the track, those CTSV calipers like to eat/destroy the (rubber) dust seals.........like every other OEM Brembo.
The Wilwood (superlites) come with SS pistons and no dust shields/rubber boots which have to be rebuilt after a few trackdays (and the red brembos like to discolor after a few heat cycles).
That and pads for the Wilwoods are 1/2 the price of a comparable Brembo.
CTSV calipers are (were) stupid cheap and the cost came out close if I went either with the CTSV or Andys setup (I ran Andy's setup for a few years). Also, Wilwood has a multitude of piston sizes to really tune brake balance. You are stuck with what the CTSV provides for standard sizing
But I do like the fact that the CTSV caliper is pretty and rotor coverage. Running Andy's brackets leave about .15" of rotor uncovered by the c
caliper/pad.
I also did a full weight comparison between the 300ZX AL and Wilwood with standard Brembo 1 piece, Andy's bracket and Wilwood superlite 1.75 and the weight was a few lbs lighther than a 300zx AL setup. So I assume even lighter yet than the comparable CTSV setup. I will have to dig up my full spreadsheet and comparison (posted elsewhere on the net with associated pictures). Standard Brembo rotor is 20.5lbs a piece. A Z1 2 piece setup is about 5-6 lbs lighter yet.
Just my 0.02c.........
I
Blue55 05-09-2017 10:08 AM
I paid $250 for a pair of brand new calipers on Amazon. There are sometimes very good deals to be had. Currently they run $300 for the pair.
