-   -   SR 240 car won't crank, electronics work fine (#/f/showthread.php?t=338525)
Sean P. 08-20-2010 02:33 PM
So in my sr swapped 240 when I turn the key all my electronics work perfectly but there is zero response from the starter. Sometimes it will crank first try and work fine, sometimes after five minutes it will crank and then start fine
Could it mean i need a new starter?
This all started after I relocated my battery to the back and got a new cheap schucks battery.
Please help :[
VNG704 08-20-2010 02:38 PM
after moving it to the trunk? try making sure the connections are tight and clean.
Sean P. 08-20-2010 04:16 PM
Could a loose connection still be strong enough to power all the electronics but not strong enough to even make the starter respond at all?
Sean P. 08-20-2010 05:31 PM
So while cranking now I can hear a click (from solenoid I believe) but no activation of the starter at all.
I think I need a new starter
arsenics14 08-20-2010 06:03 PM
There is a very small wire that clip on the starter on the top side toward back of bottom of intake manifold.
Mine came off before and I thought I needed a starter but found it was just that wire had come unclipped. It slides onto a metal prong.
If that wire is connected have someone tap the starter with a hammer while u crank it over..
Sean P. 08-20-2010 06:18 PM
This has been happening for months though, would that still happen with the wire unclipped?
arsenics14 08-20-2010 06:25 PM
No, I just read your first post, didnt know it was happening over and over.
My ka use to do what you desribed and finally the starter went out, but within a few months.
I would check all your connections like someone above said, and if it still gives you problems it is probably the starter..
Sean P. 08-20-2010 06:52 PM
K I'm gonna go over all connections and get the battery tested as well
VNG704 08-21-2010 09:45 AM
also would like to add that a weak battery will do this too. happened to my 4runner before. It had enough juice to power my electronics but not enough to crank over the motor. I thought it was the starter solenoid going out but I bought a new battery and everything was fine. I know you said the battery is new but you also said it sucked. Does it put out enough cranking amps?
Sean P. 08-21-2010 06:20 PM
I honestly have no clue and that is what has always been on my mind, it was the cheapest schucks battery they had because we were working our asses off to get my car running again and had limited cash.
First thing I'm gonna do is get the battery tested, if it's the problem ill just buy a new nice one since I have money now.
EDIT: Just went outside and tried to start it, first two times nothing happened on key turn, third time started just fine. Pretty sure its the battery
nissanfreak317 08-24-2010 10:31 AM
This sounds more like a flaky connection than a battery issue. Lol, if the battery was toast it wouldn't work intermittently.
Sean P. 08-24-2010 01:03 PM
I was just thinking low cranking amps, I don't know really.
I'm gonna go over all connections and rewrap them, and also resand my ground where it goes to the chassis
Sean P. 08-25-2010 01:06 AM
EDIT: nevermind this wasn't it
Sean P. 08-25-2010 03:56 PM
resanded ground, nothing changed
All connections are good, checked over them all.
Any ideas?
McCoy 08-25-2010 04:07 PM
Put the battery back up front and see what happens.
VNG704 08-26-2010 03:15 PM
post battery's specs.
joshuaaaron 08-26-2010 03:34 PM
try sanding the connection going into the starter. mine had alot of corrosion and had the same issue sanded them clean and i've been mint ever since :)
