-   -   ISIS SR20DET Radiator from enjukuracing.com (#/f/showthread.php?t=224601)
s14sport 11-13-2008 02:24 PM
ISIS SR20DET Radiator Install & Review
I just received my new ISIS sr20det radiator for my S13 from www.enjukuracing.com
Below are the pics and comments of the install process and my opinion about the quality of the product.
http://www.eternitypcs.com/misc/isis/01.JPG
First off the radiator came shipped in a sturdy box with plenty of protection all the way around.
http://www.eternitypcs.com/misc/isis/03.JPG
Overall quality of the piece was pretty good.
Welds were good and the inlet and outlets were straight and in the right position for install.
http://www.eternitypcs.com/misc/isis/04.JPG
Closeup of welds
http://www.eternitypcs.com/misc/isis/05.JPG
Closeup of welds
http://www.eternitypcs.com/misc/isis/06.JPG
Included ~1.1 bar radiator cap
http://www.eternitypcs.com/misc/isis/07.JPG
This is my car (S13) with sr20det that the ISIS radiator will be going into.
I already have a Koyo radiator which I will be replacing with this ISIS one because I recently got a hole in it.
I will compare the ISIS radiator cooling ability to that of the Koyo which I know was good.
http://www.eternitypcs.com/misc/isis/08.JPG
To install: Take off hold brackets. I'm using the S14 hold brackets on my S13 because I think they look better.
http://www.eternitypcs.com/misc/isis/09.JPG
Take off coolant overflow line next to radiator cap
http://www.eternitypcs.com/misc/isis/10.JPG
Next tackle the cooling fan. I have an efan already installed
if you still have the stock clutch fan you can probably skip this step and just uninstall the fan shroud if you still have it.
http://www.eternitypcs.com/misc/isis/11.JPG
Remove the electric fan from the radiator. Usually zip ties hold it on.
Mine has alittle spot for a flathead screwdriver to screw the zip tie back out through the radiator.
http://www.eternitypcs.com/misc/isis/14.JPG
Next uninstall the lower radiator hose from the thermostat housing pipe.
http://www.eternitypcs.com/misc/isis/16.JPG
Then uninstall the upper radiator hose.
http://www.eternitypcs.com/misc/isis/17.JPG
Next pull out the old radiator it should be a breeze and place it down on something
that won't bend any of the radiator fins (unless you don't care about the old radiator).
On the bottom of the old radiator the rubber grommets might still be connected to the two nipples on the bottom of the radiator.
Take these off and install them on the new ISIS radiator.
http://www.eternitypcs.com/misc/isis/18.JPG
My camera ran out of battery so I didnt have a pic of this, but, next you should install your new radiator hoses onto the
new ISIS radiator and leave the hoses alittle loose so you can move them for fitment later.
Slide the new ISIS radiator into place and proceed to install everything back as normal.
http://www.eternitypcs.com/misc/isis/19.JPG
Start with the lower radiator hose. Install this back onto the thermostat housing pipe and tighten both clamps when you have the hose fitting properly.
http://www.eternitypcs.com/misc/isis/20.JPG
Install the upper brackets to keep the radiator in place.
http://www.eternitypcs.com/misc/isis/21a.JPG
The fitment of the ISIS radiator was great.
http://www.eternitypcs.com/misc/isis/23.JPG
Install your upper radiator hose back.
http://www.eternitypcs.com/misc/isis/22.JPG
Reinstall and connect your electric fan, clutch fan shroud, etc...
http://www.eternitypcs.com/misc/isis/24.JPG
Install your coolant overflow hose.
http://www.eternitypcs.com/misc/isis/26.JPG
Now refill all of your coolant and bleed the system of any excess air.
After bleeding the system of any excess air in the motor the radiator worked as expected. Very well.
There was absolutely no difference in the performance of this radiator then that of the Koyo.
I have driven it hard and daily driven it and the temp gauge has not changed.
Even after a long drive I can put my hand on the radiator and its not super hot.
I would recommend this radiator to anyone who wants to upgrade to an aftermarket radiator, but, doesn't have the money for a Koyo or equivalent.
blueshark123 07-09-2009 11:25 AM
why u change radiators for?
gunmetalr32 07-09-2009 12:01 PM
if you read the tread. he said he got a hole in the koyo
migit 08-28-2009 09:16 AM
Cool dude, thanks for the good post! I have a ISIS radiator sitting in my garage waiting to be installed. Good to hear no change in performance vs the koyo. If I have any different results after installing mine I'll post them up here.
240sxcure 11-19-2009 02:07 PM
Is it possible to get side by side comparison's with the Koyo?Measurements of the two radiators with temperature readings for comparisons?People are always knocking ISIS for china made parts, but I would want to see how they perform against some of the established brands.
Enjuku Racing 11-19-2009 02:18 PM
The overall dimensions between Koyo and ISIS are virtually identical on core size. As for Temp reading... Never had any issues with one not cooling properly. I used one on my personal car and works great. We have sold a few hundred ISIS radiators and they all seem to still be working great!
thanks
Ken
