-   -   B&M Short Shifter noise (#/f/showthread.php?t=228336)
miklos 12-07-2008 02:43 AM
I'm getting a weird vibration noise at certain rpms and when I accelerate. When I hold the shifter arm it stops.
What could it be?
DreamN 12-07-2008 03:07 AM
crappy trans mount maybe?
blackrms13 12-07-2008 03:09 AM
doesnt that happen to all SSs?
slider2828 12-07-2008 03:43 AM
Yes it does happen to all SS. Search for a thread on a fix for that.... which is wrap the counter weight with electrical tap. Counter weight is the hump in the center of the actualy stick...
silviachik420 12-07-2008 04:02 AM
also its becuz the B&M is a soild shifter try not to use a metal shift knob, get a nismo resin.... fixed
iitywygms 12-07-2008 04:36 PM
Mine rattled until I put washer on top of the springs that hold the shifter in place. Remove the round ring from the shifter, you will see the springs I am talking about. Add a couple of washer to make the springs push down harder, it will keep the shifter from rattling. At least it did for me.
Paul2x 12-10-2008 12:29 AM
yeah they make a bunch of noise at higher rpm's
projectRDM 12-10-2008 09:47 AM
What he said, more spring tension will quiet the noise a lot.
