Wiring harness question, any insight is appreciated!
Can you use a 96 wiring specialties trans harness in a 240sx that is 97-98? I currently have one in my car but I'm having wiring issues (battery not charging, starter plug and alternator plug not working) so I am now wondering if this a compatibility issue?
I believe they’re chassis specific, s13 vs. s14 not year specific. But I could be wrong. I can’t tell the difference between my 96 and my friends 95.
not 100% sure. I think the 95-96 are different from 97-98 due to the obd 1 and 2.
Yeah I didn’t think about them going obd2. Sent from my iPhone using Tapatalk |
I was thinking this was the issue, but I wasn't sure.
I have a 96 main engine harness and that appears to be compatible so that's why I was asking about the trans harness. Now I'm wondering if a 97-98 trans harness is compatible with the 96 engine harness..
There are 4 different harnesses in the 96 model year... obd1 manual, obd1 auto, obd2 manual, obd2 automatic. It all depends on the production date of your car ...
Sent from my SM-G950U using Tapatalk |
Its such a cluster fuck between 95-97, the one year 1996 is like a breed/mix of 95 and 97. The FSM has sooo many wrong wires. I recently wired an LS swap into a 96 and had to use both 95 and 97 diagrams to get it straight. And I am still lost with some of it.
FWIW you need the right year harness, and if its a 96 then you might actually need to try different 96's until one works. Some people will list a 95 harness as a 95-96 for example, or say sure S14 zenki harness. |
Hi I work at Wiring Specialties - this harness definitely is only listed compatible with 95-96.
https://www.wiringspecialties.com/s1...ss-oem-series/ Shoot an email to [email protected] and a tech can most likely help you figure something out - change connectors, swap alternator, get charging system working again with a resistor, etc. |
| All times are GMT -6. The time now is 12:31 AM. |
