-   -   Need help identifying what exactly this is and does. Black wire on ignition switch? (#/f/showthread.php?t=542102)
tunersedge 10-29-2013 04:33 PM
I have searched and have had no luck. Checked the FSM and wasnt able to determine what exactly this wire does..Hell i dont even know if wire is the appropriate name to identify what this is. Anyhow...what is this and what is its purpose?
http://i.imgur.com/KXvkWcd.jpg
hobbs 10-29-2013 04:58 PM
Auto shift lock, prevents you from removing the key when the car is not in park.
tunersedge 10-29-2013 05:06 PM
thank you for the clarification, the owner of the car before me did a hack job with the wiring...the car was an auto to manual conversion so I was clueless as to what it was. Its snipped after about 4 feet, should i leave the wire as it is or remove it?
hobbs 10-29-2013 05:26 PM
It's actually a cable not a wire, I would disassemble it at the cylinder and pull out the lock. Although I have no idea how the mechanism works.
