G35 rear hubs on an S13
I came across a pair of G35 rear hubs and I wanted to know if they could be used with the stock S13 knuckles. I read that only the G35 rear hubs will work on an S13 but I did not know if they meant with stock S13 knuckles or G35 kunckles.
Any help would be appreciated. |
I would be interested in knowing too.
I know no one has gotten back to us but I have learned that both the G35 and the S13 both have the same center bore sizes.
S13 center bore is 66.1mm G35 center bore is 66.1mm So it will fit. However now I want to know if I can use my 300zx rotors on the G35 hubs. I read that both the G35 and the 300zx have the same rear rotor size The G35 is a 11.6 vented rotor The 300zx is a 11.6 vented rotor Unless someone has a definite answer I may just try it out to see if it will all work and make a write up if so. |
My mistake. Thanks for correcting me.
The stock S13 rear axle nut on the hubs is 36mm while the G35 has rear hubs with 32mm axle nuts. Does this mean for sure this swap will not work?
Conversion hubs are $250 for a set of four.
Just go the easy route. Why try to reinvent the wheel. |
| All times are GMT -6. The time now is 11:05 AM. |
