-   -   engine bay harness (#/f/showthread.php?t=513549)
lbkid180sx 04-15-2013 10:06 PM
engine bay harness
looking to get a diagram for all the plugs, fuses and relays in the s13 engine bay, im doing a carbed v8 swap(no flaming) and im not running any engine harness and need to see if i even need it or what i can eliminate
lbkid180sx 04-19-2013 02:00 PM
no one has a link to a thread or a pdf with the wiring diagram or manual ?
Torq_Meister 05-07-2013 08:07 AM
Cant search for fsm but attempting a engine swap :confused:
....good luck
Let me google that for you
lbkid180sx 05-07-2013 12:08 PM
searching for somthing on the internet and doing a engine swap have nothing to do with each other...and not attempting this will be my 3rd engine swap with this car so......thanks tho
mattsil80wis 05-07-2013 12:11 PM
here you go mike
#/f/tech-talk/290700...ster-list.html
lbkid180sx 05-07-2013 12:30 PM
HEY MATT!!! lol thanks .... my motor gets finished this week!!
Mikester 05-07-2013 01:40 PM
Hmm... Really.
^^ Not really sure I'm smelling what you are stepping in ^^
However, I do wish you the best of luck with your swap. The internet will still be here if you run into trouble ;)
BTW posting on Zilvia with a "no flaming" disclaimer is sort of like walking into a gay bar and yelling "No homo!" Best way to not get flamed is to not say dumb stuff, or just own up when you get called out for clearly contradicting yourself. Hope this helps ya in the future.
Mike
lbkid180sx 05-09-2013 08:39 PM
yea still dont see how internet searches and physically doing engine swaps have anything to do with each other
Mikester 05-09-2013 09:42 PM
Then do us all a favor: Quit asking for diagrams ON THE INTERNET since it has nothing to do with your swap...
Jesus... If I didn't know any better; I'd swear you were my 19yr old pretending to be someone else ;)
lbkid180sx 05-10-2013 04:43 AM
i could easily put the harness back into the car where it was and finish my swap without the diagram but im trying to relocate the fuse boxes that has nothing to do with the actual swap itself its somthing extra that im doing
quickdiversion 05-15-2013 12:46 PM
Best way to do this is what the guy that did my VH45 harness did. Find all the signals you want and remove the rest. Use the FSM for the car and the motor. Find what signal you want on each end and simplify
lbkid180sx 05-15-2013 01:57 PM
but the motor im using is a carbed chevy 350 and it doesnt have a engine harness for signals so, im just going to take it somewhere after my motor is in and running and tell them do what you want with it make it clean
Synistar13 05-15-2013 07:14 PM
which would be basically EVERY wire in the harness, since a ShebyTreeFiddy can run with nothing more than power to the alternator and starter, and a ground. Use the FSM that Matt has given to you to get the coolant temp sensor signal wire, starter activation wire, tach signal, and maybe an oil pressure signal wire (if you are not running an aftermarket oil pressure gauge). Separate these wires, route them where they won't get pinched/burned/chaffed, wrap them in wire loom, and you are good to go. Less than a few hours of work, since you are just eliminating the rest.
lbkid180sx 05-16-2013 04:10 PM
thats what i figured i was gunna do, going to do this very soon ... motor comes in next week
