-   Mid-Atlantic States (#/f/forumdisplay.php?f=33)
-   -   SR20 Redtop install help in NJ? (#/f/showthread.php?t=202501)
cinek10 07-11-2008 08:45 AM
I did my SR swap and the engine cranked and wouldn't start, now it doesn't even turn anymore. If somebody is willing to help out for some breakfast beers / food LMK. I'm in central NJ 08879
elfenguard911 07-11-2008 09:43 AM
hows the timing?
cinek10 07-11-2008 09:47 AM
Originally Posted by elfenguard911 (Post 2170936)
hows the timing?
That's the first thing i'll be doing sat morning. Would CAS cause the engine not to crank at all?
aNskY 07-11-2008 08:27 PM
no it'll still turn it just wont start. check the signal wire to your starter (butt splice type plug onto the tab on the starter)
check your timing once its crankin. do you have fuel? spark?
cinek10 07-14-2008 12:08 PM
I reset the CAS on Saturday, after i checked all the wiring i did after making sure every wire was right and i started looking under the steering wheel, it turns out that the clutch pedal wasn't pressing on the clutch safety button thing...:bash: :bash:
My baby runs great! I just need to verify that the timing is right!
Thanks for the help !!
