-   -   S13 steering rack spacer options for moar gangster angelz? (#/f/showthread.php?t=540597)
Black R 10-17-2013 07:16 PM
Hi guys,
I currently have tein inner and outer tie rods on my s13.
I also installed the small spacer they include to give a couple degrees more angle.
I've been pretty pleased so far (with one minor exception), but I'd like to add more angle.
What I don't like about the spacer they include is that there's no locking mechanism like the stockers have. They recommend loctite, and although I used it exactly as directed it still bothers me that there's no physical locking mechanism.
I've purchased a hicas rack for fewer turns lock to lock, and when I swap this in, I'd like to add more angle as well as hopefully have some kind of locking mechanism for the inner tie rods + spacers.
Do you guys know if I can buy another tein spacer and install it on the other side of the rack as well?
Or is there a better type of spacer (bigger?) that will give me more angle and still have some type of locking mechanism?
StealthG-Man 10-17-2013 10:22 PM
If you want more angle with the option of using the locking tabs then there is always the option of using modified knuckles. I am personally using Parts Shop Max's forged angle knuckles, eccentric steering rack bushings, and locking tabs on my Ikeya Formula tie rods. Along with a few other parts, I've been able to achieve the maximum 62 degrees of lock on the knuckles with only 2.5 turns of steering from lock to lock.
These parts cost me a pretty penny, but you can use GKTech's tie rod spacer kit 4130 high tensile steel steering rack spacer set to get more angle for a pretty good price.
sleepyS14se 10-18-2013 08:56 AM
^ i am interested in the gktech spacer kit...
it says to trim the tie rod end. i would like to see images showing what needs to be trimmed 13mm.
Black R 10-19-2013 07:08 AM
Thanks for the ideas guys.
I saw this post in the roll center and suspension thread:
Originally Posted by GKTECH (Post 5398507)
time for some track testing. The current Australian dollar is good for you guys. The intro price is going to be $199 AUD including our sales tax which is $181AUD excluding our tax = $162USD + delivery.
40mm roll centre correction and a little over 60 degrees of bolt on steering lock.
https://fbcdn-sphotos-g-a.akamaihd.n...38416770_n.jpg
Looks like they should be out soon...
VIPDRFT 10-19-2013 07:56 AM
JESUS FUCK! There are two threads devoted to this! Use the SEARCH tab!
#/f/tech-talk/296725...on-thread.html
#/f/chat/297481-smal...w-threads.html
awgdawg 10-23-2013 01:57 PM
I saw this dude in Australia was selling stock modified knuckles for $400 or something like that. If you have access to a welder I would just cut your stock knuckles at the tie rod part and move it slightly. Youll have to look somewhere where someone has done it to see where to move it.
sleepyS14se 10-23-2013 02:20 PM
i want/need these right now.
any more info????
rb25 run 10-23-2013 03:46 PM
wow man its pretty cool awesome i want this can i have link please ??
Black R 11-01-2013 10:51 AM
Idk the link - maybe google gktech?
Here's a cheap solution:
http://www.gtfactory.jp/cms/e107_fil...0_p1030255.jpg
