S13 350z axles villains stubs
I?ve been running a 5 bolt j30 diff for years in my 1j s13 playing the axle game and finally decided to build a proper rear end. So I picked up a spare s13 subframe, made it all pretty and built it outside the car. The diff i picked up is a q45 w/ speed sensor with villains axle Stubs installed, got the pbm solid mounts, new 350z axles, all that and put it all together. The driver side fit in snug perfect, I actually had 10m gtech axle spacers that I took out of that side because the figment was a little too tight. Go to put the passenger side in and it is wayy small, I had to stack both my 10mm spacers on the one side to make the axle fit the same as the driver side. Has anyone else running Villains axle stubs had this issue? I do have all adjustable arms but they are all in the same position as when I took them off the car and I believe them to be adjusted pretty damn even on both sides. https://uploads.tapatalk-cdn.com/202...72cea5237b.jpg
https://uploads.tapatalk-cdn.com/202...9ba1753e80.jpg https://uploads.tapatalk-cdn.com/202...95bb34898a.jpg Sent from my iPhone using Tapatalk |
You're probably using two driver-side axles. They're different lengths.
It?s actually the short side that?s too short, the axles are two different lengths for sure, but the passenger side has a lot of play still, it would almost work better with two driver side axles
| All times are GMT -6. The time now is 07:23 PM. |
