-   Engine Tech (#/f/forumdisplay.php?f=96)
-   -   how do i remove egr pipe from the valve? (#/f/showthread.php?t=469394)
dkim1985 08-05-2012 02:08 PM
so I'm trying to replace my egr valve.
how do I disconnect the pipe from the egr valve?
I'm in california so I'm trying to do this to pass smog.
StryfeS13 08-05-2012 08:54 PM
Take the whole egr valve off with the pipe attached so you have space to work. Get the huge wrench you need for that, heat it up with a torch and twist it off real quick...shouldnt be too hard!
future 08-05-2012 09:05 PM
Its really fun! Just like the heater core hoses
Good luck
dkim1985 08-06-2012 01:31 AM
the bolt on the pipe is rusted. i used a 24mm and 23mm wrench. neither worked. 24mm was too big and would just start to grind the bolt. 23mm is too small..
now what?
i just changed the BPT valve and now my idle dips super low, almost stalling.. dont know what could of gone wrong..
StryfeS13 08-06-2012 10:24 PM
I actually usually use a standard size wrench to take that nut off.
As for the stalling..vacuum leak? idk.
dkim1985 08-06-2012 11:35 PM
whats a "standard size" wrench?
the car doesnt' actually stall.. it only happens when im driving and i drop the clutch. Instead of returning to idle, it'll just drop below where it'll almost stall and come back up. I was thinking a vacuum leak too..don't know where though..
Gordo714 09-06-2012 11:41 PM
sprayed WD-40 the night before, removed other parts in way (including hood), used adjustable wrench got an angled that would allow me to put all my weight on it, and gave it a quick jolt, boom got it off, at first i was going to remove the entire intake manifold but took a sandwich break and was able to take this badboy off. just get in there and start wrenching playa!
dkim1985 09-11-2012 10:30 AM
ok soooo..
i eventually got my egr switched out..ended up just undoing the pipe on the egr side.
but...
the exhaust side got sprayed with 'liquid wrench' and wd40..and now i think theres a leak there..
after driving for a bit, the engine bay will get hot(hotter than normal) especially on the exhaust side. I can put my hand on the hood and it'll be hot. it'll get warm near the pedals if i'm driving on the freeway for awhile.
how can i fix this? is there a way i can add something to maybe "close" this leak?
dkim1985 01-27-2013 04:05 PM
is there any kind of flexible pipe that will withstand the heat from the exhaust in replace of this metal egr pipe?
i want to cut off the egr pipe completely and just put it some kind of flex pipe so it can be adjusted.
