-   -   S13 auto belt quick question (#/f/showthread.php?t=526509)
Thedriftbadger 07-07-2013 09:49 PM
I went to get my auto belts fixed and they said they can't do it cause the computer is discontinued. That's bullshit cause it's lifetime warranty and if you discontinue the parts then you're not honoring the warranty.
Well Anyway here's my problem.... The belt is stuck in the forward position and i'm wondering is there a way to move it back and lock it in place? I can deal with putting the belt on every time i get in the car, but it bother's me that i only have a lap belt. I just want something there while i sort this problem out with them.
Tiffanythe240 07-07-2013 10:57 PM
mine is the full opposite, stuck in the back position, so id love to heara way to fix this
cotbu 07-07-2013 11:21 PM
take off the trim panels, use an Allen wrench on the motor
then disconnect the plug.
disconnect the plug for a day or 12hrs plug it back in, when you plug it back in the motor should start unless it's broken in some fashion or the a electrical/wiring problem. More dramatic if you plug it back in with the door closed.
OP this should work for you too!
I've done both of those methods twice in 8yrs!
Thedriftbadger 07-08-2013 12:49 AM
Thanks, i'll try that.
Do you know if sohc and dohc cars use the same controller? Found one for sale localy, might just grab it, but its from a single cam car.
StealthG-Man 07-08-2013 03:33 AM
sohc and dohc should be the same controller. If none of the previous methods work, you can swap them out for S14 manual seat belts. They are a direct bolt in.
Thedriftbadger 07-08-2013 07:36 AM
Thanks.
And yea i was thinking about the s14 belts but honestly i kinda like the auto's lol. And i want nissan to fucking fix them like they are supposed to
Thedriftbadger 07-16-2013 09:46 AM
Well the first dealer bullshitted me and told me the computer was bad, so i replaced it and it didnt work. So i went to another dealer and they're gonna fix it. The motor and track are bad. Should be fixed this or next week!
