-   -   Coilover installion question (#/f/showthread.php?t=643394)
Zeph331 03-13-2017 10:00 PM
Hey guys i have a quick question, when i unloosen the rear coilovers and push it off the spindle, the arm/spindle wont drop down as it is untensioned. I have to jump on the spindle for it to go down. Why is that?? I remember my previous 240 never had this problem.
thanks
Standard 03-13-2017 10:06 PM
Could be that the rear links weren't torqued with the weight of the car loaded, and the rubber bushings are binding? Are the rear arms stock or aftermarket?
Zeph331 03-13-2017 10:09 PM
Hi thanks for the quick response, the rear arms are aftermarket. Im not sure if the rubber bushing is binding or not, but when i jump on the spindle for it to come down, i can hear squeak squeak squeak as im doing it.
TheRealSy90 03-13-2017 10:29 PM
Its because you have a sway bar connected from the lca to the lca on the other side of the car and you are fighting the sway bar.
