-   -   kae to kade now the speedometer doesnt work! (#/f/showthread.php?t=192016)
fast250sx 05-11-2008 04:26 PM
like the title says i did the swap and now the speedometer doesn't work any tips?
DreamN 05-11-2008 05:20 PM
Did you use the DOHC cluster?
j87w 05-13-2008 08:30 PM
As he said, if you didnt use the DOHC cluster your going to need one.
91drftr 05-13-2008 10:49 PM
thats kinda weird cus when i did mine my spedo worked fine, it was the rpms that didnt work then i did this if this helps in any way here it is
i did this when i had mine and never had a problem its pretty simple u just gotta tap into the green cable thats on the biggest plug on the coil and run a wire from there to the tach signal cable on the small plug that comes out the ecu THIS IS JUST TO GET SIGNAL FOR RPMS as for the speed i think it should be working...... correct me if im wrong.....
