s14 seatbelts on s13
So i put sum s14 seatbelts on my s13 n now i got the pillars that i have to make a hole thru to put the seatbelts the thru... if u guys got any ideas pls lmk THANKS ZILVIANS.
drill the hole and install?
The hole is basically so you can run your B pillar plastic, the hole for the seatbelt assembly to mount to is already provided....
Either get canadian pillars/headliner or make a big enough slit in your pillar to pass the actual seatbelt through. Ill be doing this soon, except ill be using b12 seatbelts.
To make the hole a hot blade, dremel or maybe a soldering iron will work. Havent made my mind up on which method ill be using check this out http://www.240sxforums.com/forums/934056-post15.html |
| All times are GMT -6. The time now is 10:02 PM. |
