-   -   oil leakes (#/f/showthread.php?t=509774)
project925 03-24-2013 03:19 PM
oil leakes
2 Attachment(s)
Hey guys. I'm trying to to get my 90 240sx ready for the track, but it wont pass tech with all the leaks it has. So I stuck my head under my car and found the part that was leaking the most was this:
I don't know what it is I'm guessing its an oil pump? Can anyone tell me what it is and any ideas as to why its leaking?
3735 03-24-2013 06:05 PM
Is it a KA or SR? And can you take a pic of the front
MamangSorbetero 03-25-2013 03:16 PM
Could be a lot of things. Oil pan gasket, oil pump.
It's leaking because the seals and gaskets in it have failed. Take it off and rebuild it with new seals.
Silvia716 03-25-2013 11:59 PM
With how old theese cars are getting your probly better off getting a new oil pump. It will come with a new gasket as well, you really want to make sure your engine is staying lubercated.
dallasb53 03-26-2013 08:53 PM
check your front main seal... notorious for failing on nissans. i have to replace mine soon
project925 03-27-2013 02:51 PM
Thanks you guys. I found out the part I was looking for was the oil pump. I still have not found the source of the leak but I will keep you posted as soon as do.
