-   -   S13 sr swap need help (#/f/showthread.php?t=623218)
Thesickkid 02-04-2016 03:50 PM
Seen a bunch of posts asking what these connectors are but none have ever posted the solution. i have a s13 with srswap got wiring specialties harness, everything is checking out alright but im having trouble identifying a few connectors and dont know what to do with them or of they go unused. cannot get pictures up right now but the connectors are all coming from passenger side fuse block, 2 pin commectors one has brown wire with white stripe and a black wire. other connector has yellow with blue stripe, and yellow with red/pink? stripe.
current symptoms (no clue if they relate):
-cyl 4 dead miss.
swapped injectors and coils. all are good. compression IS good and spark plugs are new and clean not soaked and the rockers are in good condition cant figure.
-tachometer not working
-car starts from key but upon shutting key off car STAYS on. Dash lights stay lit until disconnecting battery
hoping at least one of the 3 issues is pertaining to these connectors that i cant find a home for.
5280VertDET 02-05-2016 10:40 AM
http://www.wiringspecialties.com/sr20det.html
Plus, call them. They are extremely helpful!
Thesickkid 02-05-2016 12:27 PM
the connectors are not part of the engine harness. the connectors im asking about are part of the chassis harness from a regular 240. such a simple question for someone who already knows the answer just wish that person would see this thread.
5280VertDET 02-05-2016 12:42 PM
Maybe take a picture? Use the FSM to find the connections and then google image search that connection??
http://www.ma240sx.net/forums/printthread.php?tid=8421
I'm trying to help, but you're not helping yourself.
Thesickkid 02-05-2016 05:27 PM
yeah I took pictures couldn't upload them cause the file was too big. Don't have a computer to mess around with it or I would have had the pics up by now. Gonna try to get them up this weekend if I don't figure it out
5280VertDET 02-06-2016 08:26 AM
Take picture.
Take Screen shot of picture.
Post screen shot to imgur.
Post BB Code from imgur.
