No Spark Rb20det
I double checked everything! Switched my ignitor to a z32 perfectly swapped over plugs. Checked all my grounds. Cas spins and fires injectors when spun. I swapped the battery to the the trunk grounded the block to the frame with a 0 gauge wire unless i should add another. Im completely lost on what els to check. Idk if its a ground issue. The relays by the ecu are not bulged. The rb20 worked perfect before i took it out.
I'm about to give up. |
Bump.I checked everything again and in like so clueless on why i don't get spark to the coilpacks. If i relocate the batter where on the block and vehicle should i ground? Can a bad positive terminal be the issue? Anybody with an rb have pics if the front fjse plugs connected?.
Sent from my SM-G920T using Tapatalk |
| All times are GMT -6. The time now is 03:54 AM. |
