-   -   S14 sr20 wont start (experienced opinions only pls) (#/f/showthread.php?t=567822)
importknight 06-05-2014 07:45 PM
97 240sx s14 black top sr20.
Ok guys thx for taking time outta ur day to help. The car was working fine up untill a week ago wen I got in it and tried to start it. All the lights on the dashboard work fine but when I turn the key all the way to start the car it clicks twice and all the lights shut off and the car does not start. Also the lights do not come back on for approximately 10 minutes.
So far I have checked.
- Battery is good, even tried another battery
- battery cable is getting voltage to the starter and to the fuse box
- the ignition fuse and other fuses all have 12 volts
- tried jumping the car with another vehicle
I'm not sure what the problem could be.
- how to test if the starter is bad?
- if its a short how the hell do I find that?
- I do have a voltmeter
Any help will be greatly appreciated I need the car to get to work.
Sent from my SM-G900V using Tapatalk
importknight 06-06-2014 05:05 AM
bump this mofo
wussmonster 06-06-2014 09:37 AM
Have you checked the starter solenoid? I had to rebuild mine a e times because it wasn't engaging properly and just clicked.
Sent from my XT603 using Tapatalk 2
ultimateirving 06-06-2014 11:47 AM
Take a screw driver and jump the starter lead to the solenoid. It's really easy if it kicks over and spins you know it's not the solenoid.
There is also a clutch interlock relay that's known to go out and cause similar issue.
chetacheese 06-06-2014 12:52 PM
If you are getting a click from the starter and the lights go dim/shut off, the symptoms indicate it may not be getting the power it needs.
Where is your battery located?
If relocated to the trunk, then what is the wire set up you have?
and what they ^^^^^ said!
importknight 06-06-2014 07:47 PM
Thx guys for the response tomar after work I will give everything u said a try and let u kno wat happens
quickdiversion 06-08-2014 04:40 PM
did you check the main large grey 75 amp fuse in the front fuse box, could be going bad. I have seem them act like a switch sometimes cause they didn't completely blow
importknight 06-09-2014 06:36 AM
Yea I tried almost every fuse im pretty sure its the starter ;-/ i got it flatbedded to a shop now so hopefully its nothin more then the starter or somthin
Nikzilla 06-10-2014 06:38 PM
My money is on the solenoid
Sent from my SCH-I545 using Tapatalk
quickdiversion 06-10-2014 06:40 PM
did the little wire fall out of the solenoid?
There is a 12 gauge black wire with a male single wire connection on it that can sometimes come loose.
Nikzilla 06-10-2014 06:41 PM
It's actually a female, and the starter wouldn't click without it
quickdiversion 06-10-2014 06:44 PM
You are right, the on the SR is a female.
I was thinking of when I was under the car helping a friend find a vh45 no start. haha same damn thing, the wire was just hanging there.
hooked it up like normal, just fine
Nikzilla 06-10-2014 06:45 PM
Yeah that quick disconnect is loose as fuck. I've ripped it out one too many times while changing my oil filter.
quickdiversion 06-10-2014 06:47 PM
crush the connection a bit?
new connectors that are tighter?
or tap over it so it makes it harder to come loose.
Nikzilla 06-10-2014 06:55 PM
I'm not worried, as long as it doesn't come out by itself.
quickdiversion 06-10-2014 06:57 PM
haha true
I have never had that problem with my car, just bouncing ideas.
