S13 gas tank straps not lining up
Need some help, my gas tank straps are not lining up to the chassis holes. I have a brand new oem tank from Nissan, and I only took out the driver side rear bolt and passenger side front bolt
Sent from my Pixel 3 using Tapatalk |
if the tank is not fully in place it will have difficulty lining up the straps...i have usually gotten just one in place, put the bolt loosely on (2-3 turns) and man handled it into place to get the second one...i usually only have to do this when tank still has fuel in it, but i can see how it would have issues empty too...otherwise you may have the wrong tank for the car...
Thanks for the reply, ended up man handling it to place, I do have the original oem tank from Nissan
| All times are GMT -6. The time now is 04:42 PM. |
