-   -   oil pan gasket (DE) (#/f/showthread.php?t=430400)
soryu 01-17-2012 07:09 PM
oil pan gasket (DE)
so where is the how to for changing the oil pan gasket?:wiggle:
mines is leaking pretty bad.
Eramo323 01-17-2012 07:23 PM
its simple really
JK2005 01-17-2012 07:27 PM
It's simple drain the pan. Unbolt it. Remove the old remains of liquid gasket. Reapply and bolt it back up. Make sure you remove the RTV off of the upper pan also
Eramo323 01-17-2012 07:30 PM
also raise the engine a little so you wont have to struggle takin' it off..
loosen up the motor mounts if you dont have a cherry picker available get a good jack and jack it up where the engine meets the transmissin!
MeGusta 01-17-2012 07:32 PM
good luck pulling oil pan out just like that
bingo
soryu 01-17-2012 07:45 PM
i dont have one of those heavy duty jacks.
using the car jack ok?
Eramo323 01-17-2012 07:49 PM
borrow a floor jack from a neighbor or something... safety first ! (do not use the little bitch jacks that come for changing the spare tire)
collegekid 01-18-2012 08:30 AM
I would say just save up for a cherry picker, keep adding/checking oil until you can afford to safely change it. Buying a $35 bug thing of oil and adding a little every so often is much cheaper than anywhere from hospital bills because of an accident to a funeral. Those bitch jacks for changing tires not maintenance.
Nicelyphe 01-18-2012 08:44 AM
^^ And don't go to the local auto parts store and use the pre-cut cork gasket they may try and sell you. Just get a tube of black RTV.
soryu 01-18-2012 12:39 PM
^^don't use pre-cut cork gasket what about different material gasket?
RTV, just make a gasket with it?
BTW,how many bolts for the motor mount do i have to loosen?
waxball88 01-18-2012 12:43 PM
FSM says RTV
Eramo323 01-18-2012 05:02 PM
2 bolts for the motor mounts... Loosen the ones that connect to the crossmember...
soryu 01-18-2012 06:07 PM
would that tire changing jack work to raise the engine?
i'm gonna be using some stands for the car.
Eramo323 01-18-2012 06:12 PM
i definetly would not recommend it, there's a chance it can slip...
562s13 01-18-2012 08:14 PM
just use a jack. heavy duty jack.... your going to be working with your hand in between engine and crossmember.. heres the steps.
1.raise car on jack stands.
2.loosen engine mount bolts till almost very last thread
3.jack up engine from where the tranny meets engine and make sure to put a 2x4 so it wont damage anything. also make sure youll still be able to get to the bolts on the back.
4.unbolt the sway bar and careful with it swinging down towards your forehead lol
5.unbolt the pan in order. check fsm. taking off the pan is tricky you have to kinda manuever it around.
6. clean and put rtv on oil pan
7. repeat backwards and tighten everything.
c_mancuyas8 01-18-2012 11:03 PM
youve already got a lot of responses but I think this is what youre looking for
www.ka-t.org :: View topic - How to: S13 Oil pan removal
soryu 01-18-2012 11:35 PM
that's it Thanks.
c_mancuyas8 01-18-2012 11:36 PM
No problem good luck. Its not that hard but I hate doing it lol
