-   -   help... (#/f/showthread.php?t=281138)
McLovin 09-27-2009 02:06 PM
help...
i got a 95 240 with the stock ka24de. car starts up fine but idles rough as hell. i replaced the plugs and wires but nothing changed. i unplugged the #4 cylinder spark plug wire from the spark plug itself and the idle didnt change. i put it back then i unplugged the injector on the #4 cylinder but nothing happened. is this an injector problem or do i need a new distributor?
JEDIs13 09-27-2009 02:59 PM
check your timing
McLovin 09-27-2009 04:06 PM
Originally Posted by JEDIs13 (Post 3050925)
check your timing
this would cause the injector to stop working completely?
Ben G 09-27-2009 04:30 PM
is your injector clicking when plugged in?
Sileighty_85 09-27-2009 07:43 PM
to listen for the click use the screw driver techniqe
take a long flathead put the tip on the injector and your ear at the top of the body and listen for the clicks.
compare it with the other injectors.
If you dont hear the click replace injector
McLovin 09-27-2009 10:05 PM
thanks alot guys, ill do this tomorrow morning and post an update
scooz14 09-27-2009 11:36 PM
if it runs like shit, it most likely is not the 1 cylinder, i agree, break out the timing light.
