-   -   Car wont start with new Deatschwerks 810's?? (#/f/showthread.php?t=506987)
brandon19761 03-07-2013 08:13 PM
Hello. I just installed new 810cc injectors to try to rule out injectors as my lean idle problem... My car has a jwt ecu tuned for 740's. I thought I could drop the 810's in and just lean it out via Safc Neo... I started out at -10% which should be close to the difference between the 740's and 810's. Car won't start now...
Any Idea's??
chetos13 03-07-2013 08:38 PM
U need to retune
brandon19761 03-07-2013 08:44 PM
Originally Posted by chetos13 (Post 5169504)
U need to retune
I've got an Enthalpy ecu coming programmed for the Deats 810's...
I just thought for now I could lean it out via the safc and it would at least run... So nothing to worry about then?
codyace 03-07-2013 09:24 PM
Are the 810's the correct impedance?
Before that, I'd take that SAFC off the car and sell it on ebay...the last thing you need is a dial a boom atop a rom tune on that car.
brandon19761 03-07-2013 10:14 PM
They are high impedance from frs sport. Suppossed to be plug 'n play.
http://www.frsport.com/Deatschwerks-...E_p_27459.html
The Apexi neo was already in the car when I bought it.... It will eventually go.
Frank_Jaeger 03-07-2013 11:32 PM
Assuming you removed it, did you put your fuel pump fuse back in? Did you touch your fuel rail any? Did you prime your car a few times before going to start it?
brandon19761 03-07-2013 11:52 PM
Didn't touch the rail. Car is getting fuel. I pulled the plugs and there is fuel. Fuel pressure is good.... I didn't prime the car first no. It's gotta be the ecu..... Guess I'll know tomorrow.
codyace 03-08-2013 07:54 AM
Are the plugs fouled by chance?
brandon19761 03-08-2013 09:56 AM
They were fouled. I cleaned them up and still same...
4x4le 03-08-2013 04:13 PM
Deatschwerk injectors are junk. I have had so much trouble tuning cars with them that I no longer touch cars with them.
JWT wont make tunes for their injectors either, which is probably why you had to go with a different brand rather than send your ecu back to jwt.
Your trying to stack too many problem causing elements on top of each other. The odds of having a good running car are diminishing as long as you have crappy injectors, pre tuned ecus and an safc.
brandon19761 03-08-2013 05:22 PM
The car runs great... I was just having super lean idle issues so I decided to change injectors and ecu since everything else has been ruled out....
My harness to run the enthalpy ecu for the 810's will be here tomorrow. We'll see what happens...
4x4le 03-08-2013 06:20 PM
Have fun. I guess it seems to reason that some detachworks actually work or they would be out of business.
I have had some un tunable cars with them, and have never had one come out the way i like.
brandon19761 03-08-2013 08:09 PM
I was running nismo 740's. No better than anything else Ive encountered.
My FIC 850's were easier to tune. It's all subjective.
4x4le 03-08-2013 09:07 PM
Wait, so you know how to tune but keep purchasing pre tuned ecus? Or are you considering screwing with the tune via safc tuning?
brandon19761 03-08-2013 09:52 PM
Thanks for all your help. You can troll on now.
4x4le 03-08-2013 10:37 PM
Well that answers my question. I wasnt being a jerk, like you are now, just sharing what i know from experience.
Let us know how your mismatch of cheap bandaid parts work out in the long run. It dont seem promising so far.
KiLLeR2001 03-08-2013 10:44 PM
Excellent, I still have some popcorn packets left.
Croustibat 03-09-2013 08:08 AM
that exactly.
If you dont know, you can either learn or pay. But if you got the cheap side ... well buy cheap buy twice.
p00t 03-15-2013 01:43 PM
Were all the plugs the same? if some are more wet than others I would suspect torn or incorrect size bottom o-rings. They can leak and you would never see with the rail in-place.
brandon19761 03-17-2013 10:16 PM
If you cant leave HELPFULL comments please dont comment.
I put the new ecu in and the car fired right up. Still have to set the neo at
+20 to get the idle a/f ratio right. I know safc's are stupid for tuning!!. I bought the car this way!! Trying to weed out things so I can ditch the SAFC. I'm wondering if the PO put the NEO in just to richin up the idle mixture....?
I will go stand alone in the future, but I have other cars that need things first so I just want to get this thing running decent for now. It screams at WOT! just a lean idle issue..?
So far:
Base timing is correct
Fuel pressure is correct
Raising base fuel pressure makes no impact on idle mixture.
No boost, or vac leaks
IACV is good
New fuel filter
New N62 maf
Tried diff injectors and ecu= No change
Changed plugs and put in magnecor's-just because....
**The car has 264 cams. Could that make it idle lean??
Unplugging the o2 sensor makes no change to A/F ratio on wideband....?
Could bad o2 sensor make it idle that lean??
OrangeVirus1 03-17-2013 10:28 PM
+1 Deaschworks are garbage.
helpful: check the connectors to the injectors.
check your fuel pressure reg.
check that your wideband 02 sensor isn't dead.
raising pressure and not getting difference in the AFR.. I'd say dead wideband 02. they are like 50 bucks. replace it as insurance
brandon19761 03-17-2013 11:05 PM
Ok.
I will get a new wideband o2 sensor coming and replace the factory nb o2 sensor. The wiring on this car all looks pretty good...
what's the best way to check injector connectors? Just put in new adjustable fpr.... 43.5 psi at idle w/out vacuum. 38 psi at idle with....
Thank you!
4x4le 03-17-2013 11:38 PM
Im not saying you should go buy injector dynamics injectors, although it would be one of the best things you could do in order to get your car to run right, but......
If you want to read up on all kinds of information about injectors you should go to their website and read their tech articles. You will then understand how your cheap injectors are never going to suit you even with a good ecu, and how your safc will not allow your ecu to calibrate to the correct dead times of your injectors.
I HIGHLY doubt that your wideband is bad, but your narrow band may very well be. Changing your narrow band isnt a bad idea but since your thinking you might go standalone later, you should just fix your other cars or whatever you say your going to do to them, and get good injectors and a standalone later (living with the poor idle in the mean time).
From what I have seen with deatchwerks, you should just be happy your car runs. Take it however you want to take it but I am being honest and helpful. You will spend more time and money trying to bandaid these junk injectors and bench tuned ecu/safc than what it would cost to do it right.
You so far have:
2 ~$500 ecus
2 sets of injectors
when starting out with injector dynamics injectors (or even some lower cost msd injectors would do much better than this) and nistune or aem you most likely would not have this issue to deal with, you would have better parts, and you most likely would be money ahead.
OrangeVirus1 03-17-2013 11:43 PM
Siemen Deka's are just as good as Injector Dynamics..
I run 60lb dekas with absolutely zero issues
brandon19761 03-17-2013 11:52 PM
You so far have:
2 ~$500 ecus
2 sets of injectors
If you would read my post's. The INJECTORS are not the issue here...
I went from a jwt ecu tuned for 740 nismo injectors to enthalpy with 810 deats injectors. Made NO NO NO difference....
Injectors are not an issue here....
OrangeVirus1 03-17-2013 11:57 PM
well it can really only be a few different things :
bad 02 sensor, bad fpr, you said the fpr is new, so I'm going with bad 02 sensor, or possibly bad maf giving low voltage readings
brandon19761 03-17-2013 11:59 PM
You so far have:
2 ~$500 ecus
2 sets of injectors
How should I "do it right".?? This car is only a toy not a DD I just want to make sure its running right!
brandon19761 03-18-2013 12:06 AM
Ok. i already replaced the maf and made no difference. Guess I'll try a new o2 and go from there. Thanks.
brandon19761 03-18-2013 12:08 AM
I have noticed that there is a resistor in the maf wiring. I unplugged it and made no diff... Is the ka24de resistor usually kept with N62 maf swap?
4x4le 03-18-2013 12:55 AM
I know you said that, but the constant there is still that you have a bench tuned ecu.
Other than that, nismo injectors are good however it does take a good injector to get a good idle when using that large of an injector on 500cc cylinders. It is hard to imagine that that a large injector would provide anything but a rich idle but thats where the reading on injector dynamics website would come in handy.
The ways I mentioned.....
You have a desire for wine on a beer budget. I do suggest a new narrow band, and that could actually take care of things :fingers crossed: but if it does not your either going to need to live with the issue or step up the game with better components.
There is a reason people pay over $200 an hour for tuning on a dyno and its not about squeezing every last hp out of the engine, it is so every issue like this is at least trouble shot and if possible corrected. When something like this is encountered (by me at least) when tuning I can explain what the problem is and back it up with data, and usually fix it or make it better. I have grown to not like any large injector that is not premium although sub 700cc injectors usually are good as long as the brand is at least reputable.
I have grown to dislike cars with 5-0 injectors and refuse to tune cars with deatchwerks. If they are a good denso or jecs 700 and up injector Its possible the idle wont be "perfect"
