-   Engine Tech (#/f/forumdisplay.php?f=96)
-   -   KA24DE Torque specs (searched) (#/f/showthread.php?t=431739)
SMM 01-24-2012 08:44 PM
Ok I have searched and searched. All I am getting is mixed answers, I also looked in the FSM.
Some people are saying they stripped the cam sprockets bolts when torquing to factory specs or have even broken cams.
This is what I have come up with.
Cam Cap Bolts:
Tighten: 1.4 (FOOT LBS) in sequence then to 8.7 (FOOT LBS)
Cam Sprocket Bolts:
123-130 ......really thinking only to do 90 ( FOOT LBS )
Idler Sprocket Bolt:
40-60 FOOT LBS
Others:
Crank Pulley 150 FOOT LBS
Chain Guides 17 FOOT LBS
Chain Tensioners 7 FOOT LBS
Promise Land 01-25-2012 11:22 AM
I think the Jim Wolf instructions for changing the cams also mirror the FSM specs.
let5l1de 01-25-2012 01:18 PM
Stripped cam bolts and breakage?
Just use the fsm. You will be fine... Also, use the correct metric 6pt socket with cam properly locked or secure in place.
~mario
GR Performance
SMM 01-25-2012 04:31 PM
^ Ya guys over on KA-T some of them torqued them to factory specs and they broke.
Tantwoforty 01-26-2012 04:37 AM
I used the fsm, everything went fine.
Its from the factory, they made 1000's of them like that, why wouldn't it work?
For cam bolts i used a crescent wrench to hold it, put a towel under the wrench when it wedges against the head or it will make a small dent. it wont hurt anything, but it will bother you.
for the crank pully i used the flywheel bolt wrench trick.
SMM 01-26-2012 01:27 PM
PER FSM:
Cam Cap Bolts:
1.Tighten to 17 INCH LBS first in sequence.
2. Tighten 80-104 INCH LBS
Cam Sprocket Bolts:
123-130 FOOT LBS
Idler Sprocket:
48-61 FOOT LBS
Crank Pulley:
105-112 FOOT LBS
Timing chain tensioners TOP & BOTTOM:
56-66 INCH LBS
Lower timing chain guides:
9-14 INCH LBS
Tantwoforty 01-26-2012 07:12 PM
Yeah that sounds right..
I was trippin on the cam cap numbers but then i realized inch lbs
let5l1de 01-27-2012 11:21 AM
Cam Sprockets:
Camshafts do break for many reasons. Typically, cracks may occur around the outside of the cam gear ridge.
Cams are usually a victim of some sort of abuse from heat, poor lubrication, misuse or severe internal problems prior to cracking.
I have never stripped the threads of a camshaft.
Idler sprockets:
Extreme care with proper thread engagement, lubrication and torque must be used when installing this piece.
~m
grp
Mr. KA 03-19-2012 01:01 PM
First post, but I just wanted to chip in that I stripped the idler gear bolt with 50 ft/lbs (needing a helicoil) and the same went for the cam gears at 85 ft/lbs.
My motor was used and severely abused, but not turbo.
JDMRIDDAZ 03-20-2012 06:28 AM
On cam caps u don't need the tourqe specs cause it 11inch pounds
I use 1/4 ratchet witg no issue in 10yrs
And I use the oldskool tourqe wrench..
Less likely to strip cause u use tru force and watch a needle
Not a new clicking type..u can strip shit out easy
That's why I switched back to oldskool
