-   Tech Talk (#/f/forumdisplay.php?f=8)
-   -   wastegate vacuum to hotpipe or outlet pipe (#/f/showthread.php?t=480876)
Po_31 10-05-2012 02:14 AM
first of all i have a sr20det
I would like to know if anyone has actually installed a hose fitting or something else into their hotpipe as a means for the vacuum to the wastegate? i seen some people on different forums drill a 1/8 npt to the turbo outlet pipe instead, would either one of these work which would you choose
thanks
s14boy 10-05-2012 02:30 AM
just get a t-hose barb connector and cut on of your vac lines and run it from their. its simple no need to drill anything.
compactfean 10-05-2012 10:15 AM
I don't know why.everyone thinks its ok to t off a vacuum line. internal waste gates aren't supposed to see vacuum and is clearly shown in vacuum diagrams. weld in a nipple to the hotpipe, that's how I have mine setup.
Po_31 10-05-2012 10:55 AM
thanks alot
just making sure i did right the first time
waxball88 10-05-2012 02:13 PM
This
If you want to run it to the manifold just run a one way check valve. Wastegates need a BOOST source.
Hotpipe/compressor housing
silviaNC 10-06-2012 09:54 PM
sorry to get in the thread but this is how I have mine set-up. do I need to change anything on it?
I'm using option 2. is it right?
http://i973.photobucket.com/albums/a...stsolenoid.png
wangan_cruiser 10-07-2012 01:32 AM
i drilled a hole one of the couplers on my hotpipe then used this for my actuator
Turbo Quick Tap Fitting for Boost Source
works great. the closer the line to the actuator the faster it responds
