S13 vert fender harness problems. Please help me
Hey guys thanks for viewing. I recently slammed the jesus out of my s13 Convertable and being a newb to the s chassis crazy harness I rubbed through the harness under the drivers side fender. I unraveled the plastic and replaced the rubbed through wires. I though I did a good job tucking it but I didn't and it came back down and rubbed through again so I parked it. When I went to go start it again it only cranked and wouldn't start. Then the harness started glowing red and smoking so I immediately unhooked the positive terminal on the battery. Now I'm left with everything electrical being completly functional except for the rear running tailights and the car only cranks doesn't start. I would like to know if there is a repair for this or do I need to order a completly new harness. I really would personally appreciate some feedback. Thanks guys
Fix wires and change fuses
So replace them all. Then tuck the harness into the engine bay so you don't rub on it.
Update.
I replaced the burnt out wire. Not my car cranks but will not start |
Update, replaced wired and traced wire to fuse panel where it was disconnected to the fuel pump fuse
Tucked Harness up into fender with wire loom and self tapping screws after extending the whole harness 4 inches so there was no tension or reason to come back down. Bent the lip of the pinch weld up to act as a barrior. Replaced any burnt wires and covered any spots left exposed with electrical than hockey tape. Then checked and replaced all fuses and secured the fuse box to the bay. Now everything electrical is operating and I can now focus on making my vert BALLER AS FOOOOOK:cj:
| All times are GMT -6. The time now is 08:02 AM. |
