-   Tech Talk (#/f/forumdisplay.php?f=8)
-   -   Will an SR downpipe fit on an S14 KA Manifold? (#/f/showthread.php?t=679105)
Aku777 04-20-2021 10:52 AM
Hey, I was wondering if an SR downpipe would fit on an S14 KA Manifold, it really looks like it will. It seems like my s14 stock exhaust manifold exhaust flange sits a bit behind the steering column, just like the SR turbo elbow exhaust flange does.
I contacted Enjuku Racing about their SR Downpipe, but of course they said it will only fit on turbo applications since they wouldn't want to be held accountable so I could get a return on it.
Thank you for any input, I searched on this forum and saw 2 posts on it and just one accurate reply saying that "it'll fit", but I wanted to make sure so I don't waste my money. ;)
spooled240 04-20-2021 02:04 PM
I tried years ago and it didn't work. I do remember it being close enough that it could probably have worked with minimal modification.
Aku777 04-20-2021 02:11 PM
Was it too close to the frame? ISR has a KA-T downpipe which is the sr downpipe except with a 2 inch extension to make it sit lower.
spooled240 04-20-2021 05:30 PM
I remember being able to bolt it on half-assly because the angle of the flanges left a large gap. It might have also been interfering with the chassis also. This was like15 years ago..
Aku777 04-20-2021 09:27 PM
Ah I see, thanks for the input. I may buy the KA-T Downpipe, it's supposed to be 2 inches longer on one end to get more clearance.
Do you still own a 240 by any chance?
spooled240 04-23-2021 08:54 AM
Yep, still have the s14
srh666 04-23-2021 10:21 AM
All u need to do is cut & index a single 2bolt flange
