-   Intake & Exhaust (#/f/forumdisplay.php?f=127)
-   -   Enjuku Racing - ISR Turbine O2 Housing - Nissan RB20/25 Swapped 240SX (#/f/showthread.php?t=647243)
Enjuku Racing 06-16-2017 10:04 AM
https://cdn2.bigcommerce.com/server2...00.659.jpg?c=2
Turbo Outlets increase exhaust flow and free up Horsepower. Great bang for the buck upgrade. Includes all gaskets and hardware required for install. This unit does require that you re-use your OEM turbine housing studs/nuts.
This Specific Outlet has been double welded on the outside and inside to prevent cracking.
May require slight clearancing of bellhousing or flange. Due to the larger 3" diameter.
New brushed finish
*** THIS IS MADE TO BE USED WHEN SWAPPING A RB20/25 IN A 240SX ***
***The ISR RB20/25 O2 Housing Was Designed To Clear The LHD Steering Rack***
Specs:
3 bolt flange thread pitch - M10 X1.5
bolt length - 1 3/4in
New brushed finish
Whats in the box:
1x ISR Performance RB20/25 O2 Housing
1x 3in 3 Bolt Gasket
1x 6 Bolt Gasket
3x Exhaust Studs
3x Exhaust Nuts
In Stock and Ready to Ship!
$127.99
https://cdn2.bigcommerce.com/server2...g?t=1468417993
