-   -   cluster dying? (#/f/showthread.php?t=204813)
adictd2b00st 07-25-2008 07:44 AM
cluster dying?
So lately my tach has started having a mind of its own, bouncing around all over the place......yet after driving for a while it smooths itself out and acts normally. Also seems to do this in the mornings more often than anytime else, sometimes its normal from the get-go. This a sign of something in the cluster itself going? S14 SE cluster if it matters
aznrib 07-25-2008 08:17 AM
Pull the cluster and check the connections in the back. Sometimes it just takes a little cleaning and it will do the job. Check for burnt traces also. If not then you might need another cluster.
adictd2b00st 07-25-2008 10:06 AM
Will do, its possible its loose cause i know its not the original
