Low beams suddenly stopped working
I have '90 JDM S13 with the triple projectors and last night al the low beams suddenly stopped working. High beams, corner lamps, gauge cluster, and everything else is fine.
I checked these: https://i.imgur.com/Gj4SXfa.jpg?3 But they look fine. Does "H/Lamp" infer "High/Lamp"? Are there other fuses that may specifically be for the low beams? (Search results were futile and I don't have all day to keep digging so I'm hoping someone might have a quick answer.) Pic of my hoopty for your time: https://i.imgur.com/UT6JOya.jpg?1 |
Check the stalk, they're known to go bad
I got her from Japan a couple years ago and she's been rock solid ever since. I'm not even mad, as this was a regular occurrence with my Evo X. I guess I'm officially a Nissan owner now! https://i.imgur.com/EDz6q9W.jpg?1 |
giant brakes are neat.
I would also double check your grounds on the front headlight harness area. I had a similar issue and mine was due to a ground. Could be possible there's corrosion on a ground causing them not to work because of bad connection and just require cleaning.
| All times are GMT -6. The time now is 12:28 AM. |
