-   Tech Talk (#/f/forumdisplay.php?f=8)
-   -   SR bucking problem but no codes! (#/f/showthread.php?t=210309)
s13hatchback 08-26-2008 07:16 AM
I just swapped my redtop into another chassis and now the car starts bucking bad when i ease into the throttle, but it doesnt happen at wife open throttle.Mods are...
redtop
z32 maf(new)
greddy fmic
fujita intake (PoS)
Walbro pump
I put the boost back down to stock until i figure this out. The MAF is new as are the plugs and O2 sensor. The ECU is showing 55 no problems. I checked for boost leaks and intakes leaks and nothing. Anyone have similar issues or have had in the past i would greatly appreciate the help. Also the plugs are fine(beige color) and there was no fuel smell when i took them out.
Firestorm 08-26-2008 07:25 AM
is your ECU mapped for the Z32 MAFS?
s13hatchback 08-26-2008 08:29 AM
its a stock #62 ecu
clark 08-26-2008 08:39 AM
the #62 ecu is designed for a redtop SR MAF, not a z32 MAF. if your are using a Z32 MAF in an ecu that it was not dseigned for, you need some type of air/fuel controller like the ap;exi AFC, or a reflash of your ECU..
or get yourself the right MAF, or a SOHC KA24E maf.
s13hatchback 08-26-2008 08:48 AM
my bad thought i put that in there... i have an safc2
clark 08-26-2008 08:56 AM
so did you configure the safc2 to compensate for the z32 maf?
the settings are all over this forum.
s13hatchback 08-26-2008 09:08 AM
yes i did 2 in 6 out hot wire
4cyl with arrow to the northeast
HS13KLS 08-26-2008 09:21 AM
i thought it was 2 in 10 out hot wire..
i may be wrong..but thats what i thought.
check that out and see what happens
0wn3r 08-26-2008 09:46 AM
you recirculated or no?
s13hatchback 08-26-2008 10:17 AM
no not recirc. it an hks ssqv
burnsauto 08-26-2008 10:23 AM
double check that maf/wiring..granted it may be new, but defects to happen. double check all the wiring you did..make sure nothing is loose, it really sounds like the maf is cutting out/not getting a signal.
Black240Ct 08-26-2008 10:35 AM
check the voltages, im not sure if they are displayed on your safc, but get in there with a volt meter
s13hatchback 08-26-2008 12:38 PM
I believe it is displayed when you go to sensor check on the safc, though i dont know which one it is. If anyone does plz let me know...
if it is sensor 1. it is at 1.1V at idle
2 is at .25 at idle
s13hatchback 08-26-2008 01:50 PM
like i said the car idles fine but when i give it slight throttle it starts cutting out and bucking. then when i get to about 3500 rpms it runs fin again under a decent amount of throttle
s13hatchback 08-26-2008 03:36 PM
I just spent a few hours checking everything and the maf reads 1.25V when at idle and the boost gauge sits at zero even when the car is at idle. when i give it gas it starts to read vacuum until i hit boost and it reads the boost just fine.
Anyone have any other ideas?
0wn3r 08-27-2008 08:54 AM
wth? vacuum leak maybe? Mine sits at 19-21inHG at idle
BiG MiKE86 08-27-2008 09:47 AM
sounds like u has a major vac. leak - ^^^ 0wn3r's numbers are what u should be reading - Goodluck
DDSR240 08-27-2008 10:44 AM
damn I'm sorry bro I had that same problem and it turned out to be the fuel pump sock I know it sounds strange but try it. g/l
GSXRJJordan 08-27-2008 11:06 AM
Haha how can no one mention GROUNDS. Check your grounds, from the MAF to the body, from the ignition harness (coilpacks) to the head, to the body, and from the ECU to the body. That's much more likely to be the problem than SAFC settings, because your car idles correctly.
