-   -   Water temp sensor help. (#/f/showthread.php?t=525818)
theu1986 07-02-2013 07:44 PM
Hello,
i'm fairly new so plz take it easy on the noob. Anyways i was changing my oil earlier today and everything went well. except when i got into my s13 i noticed that my water temp gauge was reading zero. I am almost for certain i hit a wire or something while taking the oil filter off ( intake manifold side) But from the pic i give can anyone figure out where my water temp sensor is located? thanks alot for the help guys.
http://i42.tinypic.com/fargnr.jpghttp://i39.tinypic.com/qsleo6.jpg
240koukiSX 07-02-2013 07:48 PM
Its on the left side close to your blue hose. Its kinda hard to tell you exactly because of the pic. Nice engine bay btw
theu1986 07-02-2013 07:59 PM
yeah i figured thats where that damn thing was. the oil filter is located on that side so when i was removing the oil filter. but there r hella wires everywhere on that side lol. im sure i just hit the wire and the connection was lost. would u happen to kno if it is a connector or single wire?
240koukiSX 07-02-2013 08:15 PM
If I remember correctly there's 2 sensors near there. One with 2 wires and one with 1 wire. But I can't remember which is which :/ lol
brndck 07-02-2013 08:16 PM
The factory one is near the oil filter kinda, but the pic shows that you also have a sensor in the upper water neck right behind the CAS (cam angle sensor)
Are you talking about the temp gauge on the factory instrument cluster or do you also have an aftermarket gauge?
theu1986 07-02-2013 11:01 PM
I have the stack cluster
http://i40.tinypic.com/2l92rmd.jpg
brndck 07-02-2013 11:49 PM
You should sell me that cluster ASAP.
theu1986 07-03-2013 07:15 AM
lol. would the water sensor be located on the exhaust side since i'm running after market water temp sensor? or would it still be located on the intake man side
theu1986 07-04-2013 12:26 AM
Bump still need help. Can take more pics if required
Twiglet240 07-04-2013 02:27 AM
Its right on the bottom of your pic in the middle. Little red top guy with 2 wires coming out.
theu1986 07-04-2013 12:30 PM
Thanks bro that was it. This thread can be closed.
