-   -   s13 coupe rear tail light question.. (#/f/showthread.php?t=528689)
rhdsilvi85 07-22-2013 11:55 AM
ok so im confused.. I rewired my car with jdm wiring because I had some issues with some stuff... on my old car I had an issue with voltage dropping between the two taillights.. I used a volt checker and with my battery being low (12.2volts) at the back rhd driver tail lights it was 11.8v and at the rhd pass side it was 11.3v.. can anyone shed some light on this? also does anyone know what would cause my brake light to work and then stop working? the light on driver works but pass doesn't any tips on how to test? tried to change bulb but that didn't work..
Mikester 07-22-2013 12:43 PM
Check all of your grounds.
rhdsilvi85 07-22-2013 07:23 PM
http://i20.photobucket.com/albums/b2...ps71defa26.jpg
http://i20.photobucket.com/albums/b2...ps6607a8c9.jpg
rhdsilvi85 07-22-2013 07:25 PM
these are the two pics I have one is the ground near the rear latch and the other is the issued tail light... I noticed that the green white stripe wire is got solders I don't know if that is stock or not but that could be a issue.
