S14 trunk not closing properly. Please HELP!!
My trunk does not close all the way. The trunk is not originally from this s14 but I swapped it over because it was spoiler-less. Everything is lined up and it closed perfectly but then randomly this happened. I searched around and I tried different things and nothing seems to work.
Added new OEM striker Added new OEM latch Replaced torsion rods with OEM non-spoiler rods I adjusted the 2 bolts on the latch Below is a link to a video I made. You'll see that it closes but leaves a big gap. What bothers me the most is that water gets in because of this. https://i.imgur.com/wLid6Sr.mp4 |
U can always drill further down the adjustment holes, never done it before but it might help out ur problem??
Thanks though! |
Move latch up or striker down
Already attempted. I even replaced the striker. Still no difference :confused: |
Either way, you're going to have to find the equation w/ the 2. |
Happy 4th bump
Someone out there help me out here |
I recently fixed this on a mates s14... the latch on the chassis side, underneath was cracked on his car.... exactly the same thing was happening.
repaired/tack welded and it sat correctly. food for thought - have a good look there. |
Bump! Still haven’t resolved this issue even after replacing torsion rods, striker and latch. Anything I could be missing? Any ideas?
Have you got in the car with the back seats folded down while someone closes the trunk to determine why it wont latch?
| All times are GMT -6. The time now is 11:37 PM. |
