Walbro 255LPH High Pressure Racing Fuel Pump - %25 OFF (240SX / 300ZX) All Models
Walbrofuelpumps.com is offering a special
discount to Zilvia members on the popular Walbro 255LPH High-Pressure Racing Fuel Pumps. use promo code: ZILVIA25 and receive 25% off. This offer is currently valid for 240SX and 300ZX vehicles all years and models. If enough interest rises, we will extend this offer for the 350Z and 370Z. http://walbrofuelpumps.com/zilvia/wa...-fuel-pump.jpg Walbro 255LPH HP Fuel Pumps have been the leading standard for high-performance fuel system upgrades for over a decade. Many ?members here on the forum have already upgraded to the Walbro 255. If you have any engine modifications or plan to modify your engine, a high-performance pump is essential. Take advantage of this offer while it lasts. Be prepared and get a head start by placing your order for a Walbro 255 now. 1989-1994 240SX Walbro 255 Fuel Pump 1995-1999 240SX Walbro 255 Fuel Pump 1984-1989 300ZX Walbro 255 Fuel Pump 1990-1996 300ZX Walbro 255 Fuel Pump Nobody likes to hit a fuel cut. ?Remember to use promo code: ZILVIA25 Fuel pumps are in stock and include free shipping within the USA. all major credit cards and PayPal for easy checkout. |
I'm looking to upgrade my current 255lph to a fuel pump that will net me 5-700 HP on E85. Do you have a drop in kit available that will use the existing harness from the Walbro 255?
Thanks, |
Does it come with everything pictured? Do you need anything else when installing this?
I'm interested in getting 2 kits as soon as you answer |
Yes, It includes everything required for installation of the fuel pump.
The o-ring under the gas cap, is also recommended to be replaced but not necessary. http://walbrofuelpumps.com/img/240sx-oring.jpg o-ring is not included in the kit. however when you place your order, in the notes section you may add "please send me a FREE gas tank o-ring, as mentioned by Joseph on Zilvia forum". (please note we only carry o-ring for the 240SX) |
@Jybfan04
My recommandation for you would be the TIA485 kit, which includes the F90000267 fuel pump, rated for upto 750HP and compatible with E85. http://walbrofuelpumps.com/walbro-f9...-fuel-pump-e85 The electric connector is slightly different on this pump, however it is included and it should be an easy swap. |
Would the 255 fuel pump be ok to use on a stock ka? I'm interested in a kit for my S14.
Yes, it is perfectly fine to install a Walbro 255 on a stock engine.
Does the promo code still work?
| All times are GMT -6. The time now is 11:54 PM. |
