-   -   -t won't idle issue (#/f/showthread.php?t=376339)
ship2236 03-31-2011 10:02 PM
Basically when the car sits, I can start it, it will idle at about 1100rpm for a few seconds, then it drops to about 5-650 and dies. If I feather the throttle it will stay on for a bit longer but still idles very ruff, and if given to much gas it falls on it's face completely. Basically I can't even move it from one spot to the other.... All vacuum lines have been checked n are fine, fmic and all piping is tight no leaks, z32 maf is still working and I hear the fuel pump running(walboro)... Could it be an aic valve sticking or would that only be an issue If the car actually warmed up and idled after a few? Also plugs r new..... I'm pretty lost so any input is apreciated!:hyper:
