240sx corner window mod
How do you do this to your corner windows on a 240sx https://uploads.tapatalk-cdn.com/201...dbd6acff75.jpg
Sent from my SM-S120VL using Tapatalk |
Some sort of lighting is all you really need. Like one of those LED light boards that you can double sided tape-on. Might need some sort of cover to help direct light through.
You might have to use LED strip lights or build your own. IDK what is available out there for like a rectangle board with LEDs on it. I've built a few at my last job but we had every electronic part you could think of so it was pretty easy.(was used for interior lights) You can check out Superbrightleds.com they might have some. |
LED's will look awful. Use electroluminescent panels.
These are what I bought?https://uploads.tapatalk-cdn.com/201...1860ca690b.jpg
EL panels are what the OEM light up window louvers use. They're wild. You can cut them to any size. I don't really understand how they still work after.
Also, you'll need a 12v converter but it seems like the ones you bought come with it. |
Okay thank y'all so much!!
Will do man I hope it turn out amazing
| All times are GMT -6. The time now is 03:31 PM. |
