-   Archive and FAQs (#/f/forumdisplay.php?f=11)
-   -   DIY: Z31/2003 Altima Rear Rotor Upgrade for S14 Calipers (#/f/showthread.php?t=291877)
codyace 11-25-2009 04:05 PM
Hey guys:
I've really not been on forums much over the past few months due to school, and life...such a bum I am!
The link (to a best of 240sx link for the Q45/Z31 rear rotor upgrade on FA) is a great guide, but the fact remand that a bunch of washers were not something I wanted to have on my car. While I did not think the washers were unsafe, I just felt as if I'd rather no waste time with all of those little washers during pad change, considering that I go through a set a year with my track days haha.
Anywho, in the last few links of the tread, there was mention that 2003 Altima rear rotors may work with the setup...so being that I was going to change calipers anyway, I decided to give it a shot.
I procured a set of Z31 rear brackets from a local junk yard, and was on my way. I used a set of 2003 Altima Rear rotors (makes no difference of se versus sl model type) as well, being that the 'hat' was deeper. I was hoping that the deeper hat would eliminate the need to use all the washers to space the caliper.
So here is the install. I have included pictures with a washer between the hub and the bracket...this washer IS NOT NEEDED.Once I got everything installed, I realized that the rotor was no longer centered in the bracket, and that it would fit perfect without the washer.
So alas, here are the pics.
  • Car: 1997 240sx SE
  • Rotors: 2003 Altima (Model type of altima makes no difference) Size: 11.5" (S14 and s13 are both 10")
  • Calipers: 1997 240sx Calipers
  • Caliper Brackets: Z31 300zx
  • Pads: S13/S14 rear pads
Washer is not needed! Z31 bracket on S14 hub
http://www.codyace.com/albums/album3...p_01.sized.jpg
Same image, from front
http://www.codyace.com/albums/album3...p_02.sized.jpg
Again, washer IS NOT NEEDED
http://www.codyace.com/albums/album3...p_03.sized.jpg
From front
http://www.codyace.com/albums/album3...p_04.sized.jpg
Front again
http://www.codyace.com/albums/album3...p_05.sized.jpg
Upclose
http://www.codyace.com/albums/album3...p_06.sized.jpg
Close again
With pad...fits perfectly on the rotor
http://www.codyace.com/albums/album3...p_07.sized.jpg
from the side
http://www.codyace.com/albums/album3...p_08.sized.jpg
Upclose
http://www.codyace.com/albums/album3...p_10.sized.jpg
All together
http://www.codyace.com/albums/album3...p_11.sized.jpg
Complete
http://www.codyace.com/albums/album3...p_12.sized.jpg
Thoughts: Certainly there will be those who argue that 'Z32 rears are better' just because that's what has been regurgitated 100 times on forums, but I would love to see any quantified research showing me so. This setup allows a larger rotor with the stock calipers, stock e brake, etc etc...a perfect solution for a minimalist like me. I didn't feel like dickering around with the e brake cables, and getting the hubs, and all of this nonsense....plus it's expensive for minimal(at best) gains.
This setup worked great in many ways. One, if you're replacing the stuff like I was, it's essentially a free upgrade, sans the cost of the Z31 bracket. Secondly, I use Carbotech Xp12 pads (all around)...I can lock up street tires, so how much more 'stopping power' am I realistically going to have on the street? None, this side of a R compound or a slick, which even then is a waste of time on street.
On track I did notice a bit more neutral feeling when braking, and can honestly say that all 4 grab as the exact same time, as it should. I love the way the car reacts, and it's a general good feeling.
From a rice (appearance mod) standpoint I guess it's cool as it helps fill up rear wheels, but that would have been the last reason I ever upgraded brakes (to look cool).
Part numbers:
2003 Altima Rotor:
RAYBESTOS Part # 980070R
Z31 Bracket: To Be Added
Caliper: You can use S14 or S13 OE Rear Caliper for this, along with stock pads.
If buying new/remanned:
RAYBESTOS Part # FRC10584 (Right Rear)
RAYBESTOS Part # FRC10583 (Left Rear)
projectRDM 11-25-2009 07:14 PM
Very cool, I've known about the Z31 pad carriers for years but I've always seen them used with other rotors, and as you pointed out, washers all over the place. This is nice for people who can't do the math on measuring offset changes.
J-F(rx-team) 11-28-2009 11:02 PM
Very nice thing!! It is sure that when my rear brake are done I do this setup.
kyuusei 11-28-2009 11:57 PM
Correct me if I'm wrong, but I assume this for the most part applies to S13s as well? And that besides increased cooling/brake fade prevention from the larger rotor, actual "bite" or stopping power is exactly the same because you're still using stock calipers?
codyace 11-30-2009 01:18 PM
I can't say for sure it applies directly to the s13 setup as I have not tried this. I'm unsure if the S13 caliper has different dimensions or not. I assume it would be close or possible though regardless, just use washers to space it accordingly.
The actual power applied to the rotor is the same, but in the grand scheme, you have more surface area in the same amount of rotation. THis allows for better fade prevention, more stopping area (if that makes any sense) and a safer (these are thicker) rotor. Remember, justbecause it has more pistons doesn't mean it is always better. You can often go with agressive pads to make up for any difference. I run Carboteech XP12's and these can easily lock the tires up. With slicks it's another story :D
-CA
projectRDM 11-30-2009 02:28 PM
It is the exact same procedure for an S13.
Bushido 11-30-2009 04:51 PM
anyone know the part number for the Z31 bracket?
S14DB 11-30-2009 05:12 PM
The pedal feel and the clamping force will be the same. You have more surface area to dissipate heat but the heat transfer is the same. The big gain is the increased tq angle from moving the friction point farther away from the center of rotation.
codyace 11-30-2009 05:22 PM
Good to note!
Yea, what he said! I'm a bit 'gung hoe' / 'hillbilly' when it comes to stuff like this - as in, I'm simple - It works, and I like it haha. Not that I had a huge issue before, but I needed to change everything anyway. Figured for a track car, this was a great bolt on solution for those who didn't want to monkey around with Z32 rear brakes.
Somnambulist 11-30-2009 10:09 PM
Only problem with an S13 would be the fact it's four lug. Just redrill the rotors to four lug would fix that.
Steve Lloyd 12-02-2009 06:13 AM
I've got a pair that I was gonna use and no longer need................
Shoot me a pm if interested.
nsn240 12-02-2009 06:25 AM
Definitely gonna put this on the to list... never heard of it before.
codyace 02-22-2010 02:51 PM
Any way for a mod to sticky or FAQ this?
