Not have A/C Sucks!
Its summer, its hot, im tired of no a/c. The a/c light isnt on, i've swapped the climate controller/relay thinking it was an electrical issue. Nope. Does the light not come on if you dont have pressure in your lines??? need some help guys
what car? what motor? was the a/c always in that car or did you swap it in?
whats the situation? |
i had same problem....i had a hole in my high pressure line
my light comes on and i had my ac decide to discharge itself on the my exhaust manifold while it was hot.
IT WAS AWESOME!! |
mine dosent come on either... i just roll down my windows. problem fixed:) remember, the faster you go, the more air rush's past your face, therefore cooling you down. WOO!
but in all reality, that dident help at all sorry. |
haha the window technology has been around for ages! ITS EXCELLENT. aah. Well, its a 1991 240sx, so it has the kade. There could be so many issues with this crap.
if i were you id leave it. a/c is a luxury you don't need with a 240. if you've got a sunroof, pull that shit off mann! even more wind! YES!
chances are you in the situation like me or similar to me and don't have the $ to fix it. so id say just go without. a/c is for pussy's anyway.:P(i wish i had it) |
yup..windows dwn..problem solved haha
The light will not come on if there's not enough pressure. Welcome to automobiles, they all do that. It's a failsafe to prevent damage to the compressor.
I had A/C that blew air soo cold I could lift the sound deading tar up with just a simple fart. Making bitches nip out in cars around me was unethical so I removed the system promptly. Body sweat is a natural silicate, and having a stash of gatorades in a cooler is like have a nismo thermostat. Life couldnt be better.
had a similar problem recently, w/ loss of A/C & climate control lights
fan was blowing, but cold or hot air was not coming through the vents. At first I thought it was the climate control, and replaced that. Didn't work at all. Later brought it into a shop that works with A/C's. fortunately, it was just a bad fuse. |
Take it to a shop and get it looked at to see where the leak is. Once they find it, fix it and retrofit to R134a since R12 is in the neighborhood of $80 a can.
Like Russ was saying, if the system doesnt have enough pressure in it (not enough refrigerant/oil) the compressor wont turn on. There is a pressure sensor switch on top of the compressor that detects it. You can check to see if the compressor is good but jumping the switch, but again, thats just to check if the compressor is good and clutch will engage. DO NOT RUN IT THAT WAY, fastest way to fry your compressor.
get a can of refrigerant and a hose. this will cost you like, what, ten bucks? $12?
recharge your system. if it blows hot in a week or so, you've got a real problem. if not, you've got a 20 year old car and shit happens. |
i cant hear you over my awesome A/C i know that Mehsilvia has a vert that didnt come with A/C...in CA...crazy huh |
Since when does r12 cost anything more than 15 bucks dude please tell me where u r gonna so I noe where not 2 go 2 lose all my money
guys i just swapped my s14 ka to sr..and i need to make custom a/c lines,anybody knows where to find it or buy it or anything
I tried to recharge my a/c
Well i got the r134 conversion kit. I recharged and got the a/c light, I heard the compressor turn on but it blows warm still. AND then my light goes off. Does that mean I also have a leak as well as a bad condenser (im not sure what makes it colder)? Thanks for the help guys.
Where is fuel performance at?? I may need hoses. thanks |
no A/C sucks balls. i drive around with my windows down and half the time with no shirt on and i still sweat like a slave.. you cant show up anywhere looking fresh in this cali heat and no a/c lol
haha that made me laugh, it sucks, even on cooler days it looks like i pissed all over my back.haha
I havent evacuated or vacuum before the recharge. I know, dumb. ha
| All times are GMT -6. The time now is 08:46 PM. |
