-   Tech Talk (#/f/forumdisplay.php?f=8)
-   -   Strange Kouki S14 window problem (#/f/showthread.php?t=677727)
FaLKoN240 10-10-2020 12:26 PM
I recently picked up an S14 that needs restoration.
The other day I rolled the window down using the driver side switch, and then it wouldn't roll back up.
I took the passenger side door apart. I noticed there were speaker wires running from the driver side window switch to the passenger side window switch... I think that's how this car was wired up to have the window roll down on the passenger side.
I disconnected those wires and the window would not roll up or down.
I thought maybe the motor was dead or the regulator was stuck so I swapped the window motor and regulator, and the window switch on the passenger side.
It does not work unless you de-pin the harness and switch the up and down wires.
I've tried my main s14 window switches interchangeably and there is no change.
Has anyone experienced anything weird like this?
S14rebuild 10-10-2020 03:20 PM
Funny, when restoring my s14, i came across a problem that was super similar... rebuilt the doors was messing with the seals,trim and glass fitment and all of a sudden the window stopped working...no up or down,tried both side switches, nothing... swore the motor went bad and just my luck. Nope.... ended up being the relay for power windows actn up... it would stick and un stick at will seemed like unplugging the window switch would "reset" it and would work again till it wouldnt.... replaced the relay and no problem again.
FaLKoN240 10-12-2020 10:25 AM
Originally Posted by S14rebuild (Post 6396968)
Funny, when restoring my s14, I came across a problem that was super similar... rebuilt the doors were messing with the seals, trim, and glass fitment, and all of a sudden the window stopped working...no up or down, tried both side switches, nothing... swore the motor went bad and just my luck. Nope.... ended up being the relay for power windows acting up... it would stick and unstick at will seemed like unplugging the window switch would "reset" it and would work again till it wouldn't.... replaced the relay and no problem again.
You have a Kouki, right?
I found the fuse in the engine bay, where is the relay?
S14rebuild 10-12-2020 10:37 AM
Mine was located in the enginebay fuse box.
I unplugged it, and plugged it back in..worked then same shit, i replaced it no problem
Granted i dont have a fusebox cover and know e actly which one but it solved my problem
1997 240sx
Kingtal0n 10-12-2020 02:00 PM
usually when this happens to an S14 its the window switch, the plastic box that screws to the back of the door handle with 4 screws. The thing with the buttons on it. When mine does this I just smack it and it works again.
There is a well known issue with it getting stuck "down" and melting / creating a fire.
To avoid the issue, never put the window all the way down.
Although I thought this was a zenki only issue. I've not heard of it happening to 97+
FaLKoN240 10-13-2020 12:26 PM
1997 240sx
I see a fuse, but not a relay...
https://restomod.ninja/wp-content/up.../s14engine.jpg
S14rebuild 10-13-2020 01:19 PM
Hmmm, when i get a chance to get to the car this weekend, ill poke around n report back...
zombiewolf513 10-13-2020 01:26 PM
On the late model s14, the power for the windows goes through 25A fuse -> a circuit breaker somewhere -> power window relay -> power window amp -> drivers switch -> passenger switch. The switches are grounded to chassis. So it sounds like someone might have replaced the wiring with the speaker wires, and jumped the ground to the drivers side switch.
The relay itself is powered by a Ignition Relay #1 -> 7.5A fuse ->window relay coil
Page 9 for start of diagram, Page 211 for the relay and circuit breaker locations, and Page 155 for power window diagrams and troubleshooting (https://www.nicoclub.com/service-man...sx/1997/el.pdf)
Heres the location of the window amplifier for both windows (Marked as 'B'):
https://www.edmartinnissanoffishersp..._US_253A_3.jpg
Here's the location of the relay and circuit breaker from the FSM:
https://i.imgur.com/upMjAzS.png
I'd recommend busting out the power probe.
S14rebuild 10-13-2020 01:33 PM
Yeaaaa, circuit breaker! That you! Thats what i was talkn about not the relay^ Id pass on rep but.......lol
zombiewolf513 10-13-2020 01:46 PM
lol Im more than -20,000 in the hole. doesnt matter lol
S14rebuild 10-13-2020 01:53 PM
Jezzzzzzzz,, and i thought i was buried deep in red
Om1kron 11-03-2020 12:00 PM
not sure if your issue is similar to mine but newer 240's have the relays built into the actual switch.
the diagram someone posted in this thread the relays or "amp" as it's referred to does not exist in later models. You can take your door panel off to see if it's there. The wiring is stupid and runs under the dashboard through both of the doors and hits a fuse in the engine bay fusebox as mentioned. The fuse is normally never the culprit.
